Helll all,
I am looking to put a better fuel pump in car and well nothing seems to be clear about it. I've asked a few suppliera and they stated the pump has a regulator attached so they do not make one. I have seen a few people use a basic walboro or aem pump without issue but I can not find anything specific. The gtst has the standard drop assembly while the GTR has the lower basket the pump sits in...
I've searched here and can't find specific posts for it.. ant and all help is appreciated
https://www.sau.com.au/forums/topic/475259-r32-gtr-fuel-pump-upgrade/
Don't know about gtst but yes gtr has a cradle.
Best to do it with the fuel very empty. Trust me!
Takes a bit of stuffing around to pull the cradle out, patience is required.
After it is out, install new pump same way as old pump. Best to use factory sock imo.
There's plenty of pumps out there however walbro has a new 525/h pump.
More importantly than the pump install is doing a rewire. Simple mod. Search that too lol
I have already pulled it out thinking it was bad, and I will be doing a direct relayed power to the new one but I can't actually find a replacement pump that is labeled for thr GTR. I can find expensive nismo or hks pumps but beyond that it's something to do with the pressure regulator on the pump.
Given that they look like EVERY OTHER FUEL PUMP......
https://www.google.com.au/search?hl=en&tbm=isch&source=hp&biw=1596&bih=863&ei=8e3UW9nYBobMvwS_0q_gBw&q=r32+gtr+fuel+pump&oq=r32+gtr+fuel+pump&gs_l=img.3..0l2j0i30k1j0i8i30k1j0i24k1l6.1949.5068.0.5355.17.16.0.0.0.0.348.2420.0j9j1j2.12.0....0...1ac.1.64.img..5.12.2418....0.OzbsQNiXZAI
Yep, get this one:
High Flow Walbro 255LPH Fuel Pump High Flow Skyline R33 GTR RB26DETT https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F222562585010
Don’t know about the newer model so cannot recommend it but others seem to think it’s very good.
Edited by Robocop2310
  • Thanks 1
Buy a brand new pump not a used one out of a GTR. Many pumps will do but the Walbros will do the job. If you want to just do it once put the bigger one in so you don't have to change it to get to your new power target in the future.
4 hours ago, WantGTR said:
Don't worry about it. Even piss off that relief valve.
Walbro 525.
You seen how much power they draw? They WILL melt the stock wiring into the tank. And for no benefit for what the suse seems to want/need.
Thanks for all the input. I have planned to run a separate power feed off a relay to run whatever pump would work. I've always done that before to avoid melting or burning up stock wiring.
I'm just so confused as to what the pressure relief valve is designed to do. Maybe keep the pressure from being higher than needed?
It's the stock wiring AT THE PUMP that is the most concern here.  Not the wiring that trails off into the car.  Put a massive pump into the tank and feed it with the original dental floss wiring through the pump hat?  Recipe for voltage drop and wire meltage.  Put a pump in there that is bigger than stock (and, of course, big enough to do the job) but not too big for the wiring?  Yup, recipe for happiness.
If you go massive, you need to do more work.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
