Ams tention rods
By drifter17a · Posted
Thanks does painting on aluminium work or stop them from corroding? -
'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
So unsafe would you say now? little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting -
Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
