Hey guys - So I had issues with my gearbox coming out of 4th gear off throttle.
My mechanic looked at the joint from the shitter into the gearbox and we replaced it anyway but no change.  Then my tuner actually took it apart as he noticed the boot at the bottom of the shifter was gone so that made these quiet again and also stopped some fluid spilling over the top.  He also noticed that the shifter had some parts install wrong and fixed this (grrrr at my mechanic).
This fixed the 4th gear pop out issue but then I was driving along and off throttle again and 5th gear popped out which it has NEVER done.
Now im just confused as to why its changed from 4th to 5th with a correctly installed shifter.  Any ideas?
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/
Either an engine or gearbox mount is sufficiently stuffed to have had the whole driveline move such that the shift lever is getting pushed by the side of the tunnel hole, or, there is a problem with the selectors.  You might have lost a dowel or pin that holds the selector onto the shift rod.  Might be only partway out and wobbly.
I'm sure there are other possibilities too, but failing to imagine them right now.
  • Like 1
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7889712
Has the gearbox ever been overhauled?
Many things could contribute to this, from worn bearings to worn synchros, etc.
Something simple, try flushing the box and popping in fresh fluid. If the box is pretty much on it's way out, then potentially use Redline Shookproof to mask up the problem and drive it till the box goes bang.
(That's what I'm doing).
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7890163
Yeh the box has been overhauled once before (5 years ago).  I was thinking of doing a fluid change but didnt think that will make a difference to it popping out of gear off boost.
I may have an opportunity to get a gearbox (no transferase or shifter which I dont need) for cheap.  Then when this one is out I can rebuild with stronger.
https://www.sau.com.au/forums/topic/475273-gearbox-trouble/#findComment-7890338
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
