Wondering if anyone has made or bought a brake pressure bleeding setup for an R33 GTST master cylinder.
I need to pressure bleed the brakes in my wife's euro, so I've made up a pressure bleeder using a weed sprayer from bunnings, a Volvo master cylinder cap from the wreckers (don't have a Volvo, but most euros seem to use the same screw-on MC cap), a pressure gauge, and a few brass 1/4 BSP fittings. It fits and seals on the euro cars I have - haven't actuall bled the brakes yet but no reason why it won't work.
While I was at the wreckers I also bought a Nissan MC cap - the 3 tab, 1/4 turn style - and made up an attachment to use it on the same bleeder. I can't get it to seal onto the master cylinder - as soon as I pressurise the line it leaks like a sieve from where the cap seals to the outer lip of the M/C. I tried a couple of different seals, but still the same. I haven't been able to find an off-the-shelf cap to suit a pressure bleeder either.
Anyone done this with one of these M/C's? Anyone know of an afermarket cap or seal that would work better.
Geoff
I've got an SP tools one I use on the 32 GTR, 33 GTST is probably the same I guess as they all use the same master cylinder. SP70821
BTW thread over here for another option....note that it took me months to get the correct part from SP....
Thanks Duncan - just the info I was looking for.
What fits into the hole in the SP Tools adaptor - I'm guessing the SP kit includes something that seals and connects to the pipe. The hole looks too large to take a Nitto or similar quick connect directly. I'm not sure how I'd be able to connect my hose to it as is.
The alloy Motive adaptor looks nice, but I can't find an AU supplier.
I
  • 3 weeks later...
Just to bring this up to date - it may help others looking to do the same.
I made a pressure bleeder using a Bunnings weed sprayer, a few brass fittings, a cheap pressure gauge, and a female quick-disconnect fitting. There is plenty of info on the web about this. The main thing I did different was to put the pressure gauge at the master cylinder end of the hose, rather than trying to tap it into the weed sprayer bottle.
I've got a couple of euro cars as my wife & my daily's, plus an R33 GTST track car, and wanted to be able to use the bleeder on all of them.
The euros were easy - they both (like most euros it seems) have a screw-on master cylinder cap. I went to the wreckers (U-Pull-It in SA, so I could walk around the cars and choose what I wanted) and bought a euro MC cap. I actually got a Volvo one, as the top surface was flatter and suited what I wanted to do. I drilled a hole in the centre of the cap, and self-threaded a 1/4 BSP quick-disconnect male fitting into it, with an o-ring to help seal the fitting to the cap. To bleed brakes, remove the MC cap from the car & replace with the modified MC cap, put new brake fluid into the weed sprayer (optional - you can also disconnect & refill the MC as needed while bleeding), pump the weed sprayer up to around 15psi, and start bleeding from the furthest wheel. I connected a length of clear hose to the bleed nipple, and put the other end into a waste bottle. Cracking the bleed nipple lets fluid flow out into the waste bottle, pushed by the air pressure into the master cylinder. Repeat for each wheel, making sure the MC doesn't run dry.
The R33 was more of a challenge. I also bought a Nissan MC cap from the wreckers, and threaded a QD fitting into it like I did for the euro. When I tried this on the R33, the cap didn't seal well enough to the MC. I couldn't maintain air pressure, and if I put new fluid in the weed sprayer it leaked out of the MC cap. After doing some searching, I realised that the commercial bleeders seal against the inside wall of the MC, not against the top surface. I then drew & 3D printed a bung, with an o-ring groove, which fits into the top of the MC. I used the cap from the wreckers, with a larger hole drilled in the top, to stop the bung from being forced out by the air pressure. I haven't actually bled the brakes yet with this bung, but it holds pressure so should work fine.
All up cost was less than $30, but I already had the brass fittings, pressure gauge & QD fittings.
Edited by GeeDog
  • Like 3
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
