Guys who have done this before, what do u do??
If when running a Power FC u hit the 5.1volt AFM max reading??
DO u replace it with a Z32 or what??
When does it hit 5.1 volts? And does it stay there for long?
Hitting 5.1 volts at 7,000 rpm is not a big problem, while hitting it at 4,000 rpm and it staying there all the way to 7,500 rpm is a big problem. :(
yeap swap to z32 and it will give you more headroom
if you max out the afm near the very top say for example 6500rpm, then you can tune the 5v signal to be spot on for 7500, and just have a rich spot from 6500 to around 7400
just to avoid a lean mixture and detonation up top
i personally would just get bigger afm though
It doesn't matter what the signal says...
Power FC uses Load vs. RPM on the map, when the AFM is maxed out the load value will not increase but the rpm will be mapped out to 9,200rpm or whatever so you can still tune it properly. No need to richen it up more than usual.
I can't think of many situations where you would use part throttle at 7,000rpm+ and even if the actual load was lower than the real load you would be putting in more fuel anyway so effectively it would go rich because it was pumping in fuel as if it was at WOT until the AFM starts to read real values again.
I go through 7,000 rpm a lot of times when not on full throttle, everytime I change gear for a start. Then driving though corners holding it on the throttle, not the best time for a cough. GTST's don't have inlet air temp compensation, so my best friend when it gets very hot or very cold is the AFM. The inlet air temp change alters the AFM readings, as it measures the air flow and therefore the air density.
Personally, if it hits max voltage at 4,500 rpm, then I reckon it's time for a Z32 AFM. :P
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
