Hey guys, first post so make sure if its incorrect, etc. drop a comment down below showing my how to fix in the future.
Got a no start on my RB20DET R31.
Information prior to the no start condition:
Car was idling, has been running for weeks fine, recently fixed a leaking o-ring at the fuel rail, and while it was idling after the repair i was attempting to get the cluster temp guage working from an RB30e temp sender to the single spade connector on the factory 20det harness. Accidentaly tapped/bumped the spade (connected to the harness) against the block / thermostat plumbing and the engine just cut out and died instantly. No sputtering, etc. died as if the key had been turned off, very strange and could only imagine its some voltage serge situation.
Information relating to my diagnosis that may or may not be relevant but i thought id include:
- Fuel pump can be heard running on "ignition ON", FPR reads 0kg/cm fuel pressure, but increases to around 1-2 (30-40 or so psi) when the hose is squeezed.
- Secondary ECU has been trialed that is believed to be healthy but haven't tested for myself, only word of mouth.
ECU Pins:
50/60 - Closed circuit
10/20 - Closed circuit
107/108/116 - Closed circuit
26 - Closed circuit
58/49/59 - 12v + (ONLY WHEN PIN 16 IS MANUALLY GROUNDED)
109 - 12v +
45 - Believed to be possible open circuit, will be re-checking and updating asap.
Extra notes:
ENGINE CRANKS FINE.
- Pin 16 has 12v to the ECU harness but does not activate ECCS relay when "ignition ON". BUT when manually grounded to chassis (bypassing ECU) ECCS relay activates and pins 49/59 recieve 12v+ to the ecu harness.
- CAS has ground and 12v+, when spun by hand 1 degree wire cuts 5v respectively (per 1 degree), but the 180 degree seems to be all over the place, more like 20 degrees separation. Also when spun by hand, injectors and coils CAN NOT be heard firing.
- Injector 6 has been tested with a noid light on crank and revealed NO pulsing, entire rail has also been tested out of manifold with no injectors visibly firing on crank.
- Coil 6 has been tested with a plug in the boot, out of the head and no spark was seen.
P.S Ignore the scribbles on the photos, most are there when i've gone on tangents and probably reveal nothing about the problem, just me trying to clear the diagrams in my head, I included them simply for reference in the event they are incorrect / outdated, etc.
Any help is appreciated at this point, it's probably really obvious but i'm driving myself crazy over the past couple weeks with this and as im beginning to take on more work i have less time to goose chase and need to regain a sense of direction for what i should be investigating, thanks!
- Sam
https://www.sau.com.au/forums/topic/475284-r31-rb20det-no-start/
50 minutes ago, GTSBoy said:
Surely it has to be a fuse?
If you could point me to where i would be finding fuses for the ECU, etc. on an RB20 swapped 31 / rb20 loom that would be appreciated, the engine cont. fuse (factory fuse box) under the wheel is good and as far as ive been able to find, the rest related to the ECU would be the fusible links, which i have checked and are all ok
Nope.  Sorry.  Not my cup of tea.  Just seemed like you had the "Shorted something (your temp gauge wire) out.  That something is not directly connected to the ECU, so probably didn't burn anything in the ECU" type of event that usually then leads to a fuse popping.  Some parts of your system still have power, but others don't.  Sounds like a fuse.
Update to my findings.
Found that the ignition relay (pin 1) had no continuity, so manually grounded it, completed the relay circuit but still did not change the no start condition.
Pins 43/45 Also had low/no voltage, but unsure if that should be the case or not, pointers would be helpful.
Edited by colata
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
