Hey guys,
I'm planning on doing an engine swap of an RB25DET Neo into an R34 GT and  I just wanted to check I'm on the right track and not missing any parts! The engine I'm looking to buy comes with
*Ecu
*Complete uncut loom
*Coils with inbuilt igniters
*turbo and manifold
*Complete intake including and injectors
*J pipe
*Alternator
As far as i know all I still need is an intercooler and piping
https://www.sau.com.au/forums/topic/475294-rb25det-neo-swap/
Exhaust? Whats happening with your gearbox? Even if its factory manual you'll probably want a clutch. The brakes might need some attention too.
I'm not too familiar with NEO but I believe they have a boost sensor that goes to the ecu, and of course you need the AFM.
Should've mentioned I'll be doing the clutch! Brakes are already bigger than factory too [emoji16] thanks man! Ahh exhaust, how'd I not think of that!
My advice is to sell your car, buy a GT-t
You'll save money, time, updating your registration with a new motor, etc.
But if you're dead set on doing the conversion then don't forget the boost sensor and popping in a better fuel pump.
R34 ECUs are retarded, without it the car runs like shit. Even when on Nistune, without it connected the TP Load Index goes mental, I found out the hard way when I tuned a customer's car. I disabled the boost sensor flags, upped all the voltage limits to avoid it trigger a DTC and guess what? Still went mental. Got in touch with Nistune support and they said it's paramount you connect the sensor regardless of boost or if it is disabled
I thought about going this route but it seems to cost almost double in every situation considering it's about 22k+ for a gtt in NZ and 3.5 for an engine [emoji852]️, but thanks man fuel pump is definitely on the list and I'll make 100% sure about that boost sensor!
38 minutes ago, Tyler Elms said:
I thought about going this route but it seems to cost almost double in every situation considering it's about 22k+ for a gtt in NZ and 3.5 for an engine emoji852.png️, but thanks man fuel pump is definitely on the list and I'll make 100% sure about that boost sensor!
wow... they're like 12~14k here in Australia.
Just move over here, might be cheaper in the long run lol
Wow didn't realise how much cheaper R34 were in aus, although its not quite that bad, you can pick up a coupe gtt here for 18-19k if you hunt around.
3 hours ago, GTSBoy said:
Will need a gearbox.  The NA box will tap out after a year at the most.  Just not strong enough for the torque load.
I disagree with that, I had factory manual R33 20e that had been swapped to rb25det and the gearbox was fine after around 10 years on the factory turbo. Plenty of people drift with the 20e/20det style gearbox with 300+kw and get decent life out of the trans.
I haven't seen any that low in ages! I'm happy with an engine swap anyways [emoji16] and good to know about the box! Thanks dude
I disagree with your disagree. It might live 10 years in might live 10 minutes, 20 box behind a 25 is a complete lucky dip.
Thats kind of the story with any used gearbox though, especially 20+ years old. If its in ok condition and you have some mechanical sympathy its not like they are made of glass.
On another note, Ive seen 25det boxes on here for $1000-1500 which is crazy, you are out about $2500-3000 in NZ for one.
I disagree with your disagree doubly.  I have personally had 2x 20DET gearboxes suffer from input bearing death just with the increased torque load from a boosted 20 making only ~175rwkW.  My mechanical sympathy levels are off the fricking charts too.  I have also seen a large number of other 20DET and 25DE suffer short lives with 25 turbos in front of them.
The little gearboxes are not glass....they are rubber.  They are as flexible as a piece of boiled spaghetti and it f**ks about with the bearing life terribly.
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
