Hello,
I've done alot of searching and havent been able to find anything specifically
I just bought a 96 R33 GTST has current rego in nsw and pink slip, it'll be transfered to Vic.
It has almost 190,000 kms on it even though it has a good service history i know there comes a point where all cars need to have a major service on them, my question is what do i need to do? Never done anything more then oils, coolent and sparks
If someone could let me know what else should be replaced that would be great
https://www.sau.com.au/forums/topic/475304-major-service-needed/
You say it has a good service history - look at the history...what has been done at 100,000? If there is in fact no info, no sticker to say the cambelt has been replaced then search for a major service list (no its not the same service every time - infrequent items include the cambelt, water pump, changing the brake fluid). You will be able to find a comprehensive service list by searching.
If I pick up up a car with no, or questionable service history I do everything up and including the service required at the current odo reading or date.
For a car with 190k on it I would, without looking at the owners manual because I don't have one...
Flush every oil and fluid and replace every oil and coolant, engine, gearbox, diff, coolant, brakes
Every filter
Timing belt
Water pump
Idler
Spark plugs
I would inspect and change if required:
All heater hoses
Rubber brake lines
Brake pads/discs
Wheel bearings
Serpentine belts
Dampers
Bushings.
There is most likely alot of stuff I've missed.
Find a owners manual or post with required services at intervals
Once I have serviced the car to the best of my ability I will take it to a "good" workshop and get them to run it up on a dyno for a health check, and inspection, a good mechanic can diagnose and maybe pick some things missed by me.
As for parts, only change the things that require changing, it's gonna cost you a heap, don't waste cash on things that may not be required.
Once it's serviced the next vital step, which is most important, is to do a skid....
http://www.skyline-owners-club.com/forums/downloads/R33_All_Engine_Manual.pdf
The owner wasnt able to show me any recipts apart from a HD clutch being installed last year but they reassured me it was done.....so im going to replace the all belts, fuel filter, do the oils and coolant, tranny oil, brakes, maybe rotors if it needs doing, brake fluid as a maybe, maybe the knock sensor and thats all i can think of unless ive left something out then go get it dyno'd and maybe tunned, does anyone in the wodonga area know of any decent dyno places to go to that wont cost an arm and a leg?
Edited by FedBpy2018
  • 3 weeks later...
water pump, idler wheels, wheel bearings, diff oil, injector clean, there is a workshop manual online somewhere.  Find it and download it.
Here is one location: https://manuals.co/workshop/nissan/skyline
Unless it has an aftermarket ECU [nistune, Link, Power Fc etc] getting it dyno'ed is probably a waste of time tbh.
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
