Hi Guys!
New to this forum, Recently picked up an R32 Sedan with a swapped SR20DET Engine in it. I have some experience with the SR20 Engine but not so much on the power steering etc.
The power steering is very hard when i purchased the car, the seller liked it and didn't look into it much in the 4 months he owned the car. but I'm not a fan.
Car is running a Haltec E8 ECU, Hicas lock out bar. and i imagine standard SR20 Power steering pump.
Can anyone shed some light on this issue, and give me some guidance and how I might be able to fix it, any help is appreciated
https://www.sau.com.au/forums/topic/475313-r32-power-steering/
- I suggest check the power steering pump likely is defective and ensure you have enough fluids.
- Or perhaps a short circuit occurred somewhere like the wiring loom for the oxygen sensor killing that and affecting the power steering.
- Check HICAS fuses as it is linked to streering.
- Check speed sensor under your dash
I admire your desire to help, but there is literally no way, ever, that O2 sensor wiring will affect the steering. Never ever.
All good mate but it can happen. I'm not suggesting the O2 sensor is related to the power steering but I have heard R32's wiring looms for the oxy sensor connected to the heater fail which then affected the O2 sensor and killing the power steering. It has happened.
Actually Ben, as much as it saddens me to say it.....he's right.  Happened on my car many years ago.  Power wire for the heater on the O2 sensor is in the same loom as the PS solenoid.  When it burnt, it took out my power steer.  Was a right diagnostic f**kin' nightmare to find it too.
  • Like 1
After some research and trying to find, these doesn't appear to be a Hicas solenoid (i believe it's meant to be just below the fuse box?)
and upon checking the fuse box. the fuse i can only imagine is for Hicas( PTC Heater / 4WD ) seams to be completely missing and no pins to even plug one in.
Suggestions?
HICAS CU lives under the parcel shelf, driver's side, near the speaker.  Have a look, see if it is there.  If it is not, then you're screwed regardless of whatever else is there or not.
The engine bay HICAS solenoids are huge things, bolted to the chassis rail opposite the (engine) oil filter location.  You can't miss them if they're there.
If someone has gone full jihad on your HICAS system and pulled everything out, you will never get the PS to the correct behaviour without finding a way to get it to do what other non-HICAS Nissans do.  There must be an (electronic) mechanism to change the PWM signal fed to the rack solenoid to affect the assistance.  I haven't looked into how to do it, because my HICAS CU still works.  I have only gone as far as thinking about what would need to be done.  I'm assuming some Arduino based rig to take in the speed signal and put out a PWM to drive the PS solenoid.  Alternative would be to find how Nissan did it elsewise to HICAS and rob the module out of a similar car (Maxima, whatever the hell else was same era).
Thanks for the long reply, Looks like someone gone full mad, the Computer under the parcel shelf is not there and the Solenoid set is not there under the oil filter location. I don't quite understand why it is, that i need all of this. Excuse my ignorance, but if the computer has been replaced by a haltech ECU, what telling what to do what, or rather what can't tell what to do what that making the power steering so hard?
Ignore the Haltech/ECU situation.  It has nothing to do with anything.
Skylines (worth importing) mostly had HICAS.  HICAS did what it was supposed to do, and because it was the steering system, it was thus entrusted with the more basic aspects of running the steering system - including deciding how much assistance to give to the rack.  This is a speed based decision, and seeing as the HICAS CU was being fed a speed signal as an input to its primary task, it probably made perfect sense to just use that one module to do everything, rather than having a separate (steering controller) module as well.
Now, it is completely possible that your car never had HICAS.  If it does have a HICAS lock bar, then it probably did have HICAS.  The rear subframes for HICAS and non-HICAS cars are different and there is no need (or possibility) of fitting a lock bar to a non-HICAS subframe.  So, if you car never had HICAS, then it would have had to have something (a steering controller module) to drive the PS solenoid.....but as I said, I've never looked into what that module would have been. Trust that it would not have been the ECU, though, because they simply don't have anything to do with the steering.
Mmmmmk,
So my best guess is that because the computer can't get speed info, it can't tell the solenoid to have lighter power steering, thus it being stuck on hard steer mode? Am i close?
The car definitely has the lockout bar and the computer has been removed, the cable you can see dangling. So i basically just have live with the hard steering? otherwise re-fit the Solenoid/HICAS computer and go from there?
No.  If the computer that you are thinking of is the Haltech, that is NOT the computer to worry about.  The computer to worry about is not even in the car any longer (that would be the HICAS CU).  Your PS solenoid is currently (likely) receiving no volts.  Thus it gives no assistance.  Put 12V on it and it will go feather light.  Put something in between on it and it will give an in-between amount of assistance - which sort of is OK but will not feel nice all the time.
You do not want to be trying to refit the HICAS CU, just to get the PS working (despite what I said in my first post, which was assuming that the car hadn't been molested quite as heavily as it sounds like it has).  Putting the HICAS Cu back in would bring other problems that will just make your life hard.  So forget about it.  The solenoid you speak of....now, if that's the HICAS solenoid in the engine bay, don't think about it again. It is gone and you don't need it.  (As proof, I offer my car, from which I have removed all the HICAS gear EXCEPT the computer.  Having done a small wiring mod - which is nothing more than pulling one of its loom connectors off! - it is quite happy to run the power steering like it always did, without putting the red HICAS warning light up on the dash.)
Note that I have, at pretty much all times, used the terms PS solenoid and HICAS solenoid when talking about them so that there is no confusion.  The PS solenoid is just a little valve on the rack, that controls how much assistance you get.  The HICAS solenoids (of which there were actually several in the car originally) provided ALL the power that moved the rear rack (and locked it out when there was a fault, in the case of the rear solenoid).  Do not confuse them.
As I have said several posts ago, what you will want to do is work out what either non-HICAS Skylines did to arrange for variable assistance (by speed) or what other common-era Nissans did (if that proves easier) and get one of those modules and wire it in so it can see what it needs (power, speed signal being the obvious ones) and drive the PS solenoid.....OR.....make an arduino based controller that reads the speed signal and drives a PWM output (and probably SSR) to drive the PS solenoid.  The beauty of Arduino is that you can have other inputs on it (like a selector switch or variable resistor control) to vary the weight or change the shape of the assistance curve, and you can completely reprogram it if you make a mess of it the first time and don't like the result, etc etc.  but it requires enough electronics brains to not blow it up.
26 minutes ago, Davidbroberg said:
I will see if giving volts to the "PS Solenoid" Will give any results.
Why is it i want variable assistance by speed? To my knowledge my S13 never did and never needed it
Try 5 or 6 volts initially.  You will need a decent way to create that - able to handle enough current to drive the solenoid.
You want more assistance at low speed to make parking effort low, but you do not want that much assistance when going fast, because you lose all feel.
And the solenoid in your photo is indeed the PS solenoid.  It's bound to be able to pull a few amps at 12V. You could try measuring the DC resistance with a multimeter to get a rough idea how much current it will draw.
I think it's time to call an Auto Electrician friend, I have no idea about it.
Thanks for you help!
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
