RB26 intake manifold on RB20
So ive seen this done in Japan a few times and i got to wondering why it might be done? It seems like it would only add complication to the engine.
Is it a more responsive setup for the engine or really only "cooler engine bay" type mod?
ITBs are much snappier (throttle response) than a big open plenum - hence why the 26 had them in the first place.  Realistically, on an RB20, it is nothing more than a looks cool / internet points type of thing than being of any usefulness.  Doesn't really affect how much power or torque you can make.
So realistically its not even going to help with response on an RB20? I wonder why people do it at all? Ive seen plenty in Japan and found several companies that make full adaptor plate sets to bolt it on directly.
Edited by Hcr32typem
Shpelling arrors... :p
I did it on my car and while i don't regret doing it i would not do it again or recommend it to others. If i had my time over i would have gone plazmaman top half and a DBW throttle 100%.
Do not, and i repeat, do not buy the OtakuGarage adapter plate. It looks great but the f**king around required getting it to (barely) fit is nothing short of a nightmare and requires a lot of custom fabricaiton to be done. Who else out there is offering an adapter kit?
  • Like 2
It does look very nice those. ?
The on i found i liked in particular is a TS Factory part from Japan
1 hour ago, iruvyouskyrine said:
Got a link to it?
http://ts-factory-hp.com/product.html
Its the third product down on the left.
Im mostly interested if its more responsive mainly because the build on my Type M is to make 220kw or so but have much better response. I live in the mountains and having a super responsive package is ideal for the roads i drive.
To repeat, ITBs can in no way affect the type of "response" that most people mean when talking about turbos.  The "response" of a turbo engine is usually assumed to mean where the boost threshold is or how laggy it is (which are not the same thing).  It is not usually meant to refer to the throttle response.  ITBs are all about throttle response.  The reason they are so snappy is simply because the volume of inlet runner downstream from the throttle plates is much smaller and the effect on the flowrate is therefore that much faster.  In the order of 1 or 2 tenths of a second though....not hundreds of rpm like with turbo response.
if you want response you're going to need a twin scroll, twin gate, divided rear housing setup. ITBs don't just magically give you unicorn response, what you do get is a tiny bit better transient response.
Also On a RB20 going to a RB26 ITB you're going to actually degrade your mid range torque as well, and the bonus a laggier turbo.
So realistically its more or less useless haha.
This is exactly what i have.
RB20 with twin scroll manifold, twin scroll rear housing, twin wastegates and even some EFR magicness. And RB26 ITB's. I promise you it's not worth the money lol, ask me how i know.
  • Haha 1
How?[emoji854]
  • 1 year later...
Sorry for bumping and old post. Just wondering if you or anyone else has any experience in using this adapter plate. If so what were the main hurdles needed to get it to work.
  • 7 months later...
Now I understand.
Copied from my build thread on Zilvia
So. As the saying goes, bolt on is never truly bolt on.
This post will detail the mission, rather exercise in frustration that is getting ITBs to fit with the Otaku RB20DET adapter plates. People who have used them have just said that they are tough to get to work correctly but dont offer any details in what the process actually was.
To start,  I would like to add that they were quick to answer any questions I had over instagram and this isnt a stab at them or anything.
When I had mocked everything up on the stand there was a huge interference in between the coolant passage on the Rb26dett intake manifold and where the thermostat would like to live. Turns out that even with the proper parts it would be a game of Millimetres to get everything to play nice.
Otaku instructed to get an RB30 thermostat housing for more clearance and to modify the lower coolant passage.
I marked in black the areas I needed to further modify the thermostat housing.
Modified the coolant passage and machined down the lower screw boss to get it to clear the thermostat housing. Just clears as is but still no room for the lower rad hose.
Got the thermostat housing cut and angled down to free up some more space. Also you can see I had to countersink the top bolt hole as well. Everything finally clears. Time for "final" assembly.
I also drilled out the threads marked with the "X" this is to allow the fastener to go through both plates into the block. I was concerned that the small area around the front water port wouldn't seal correctly.
I made a gasket to go inbetween the two plates and used a light buttering of RTV to make sure everything is sealed correctly. I completed the assembly with an HKS RB26dett intake manifold gasket set.
Those are the main hurdles in getting the otaku ITB adapter kit to work on RB20det. I can see why people knock on the kit because its pretty fiddly and doesnt fit out of the box.
Now I dont know yet if it leaks or anything. This was just to make it all  physically fit.
Edited by Jordie Lewis
 Share
    • Its also very clearly made to take business away from https://theskylineshed.com/ which is legitimate and even has a physical address.
    • The 'About Us' got me ..  I added something to the cart and clicked 'check out' and none of the payment options in the footer (ie those with buyer protection) were available. Stay the hell away from this one.
    • No. Not true for any non-GTR R32. I think even the GTS4 has the GTSt knuckles with eye type lower shock mounts (as opposed to GTR fork lower shock mounts). The only R chassis in which something like the quote claim is true is the R34, on which the turbos have the fork type and the NAs have the eye type. **Edit: Actually I reserve the right to be wrong about the above statement. It might also be true on R33s. My memory on those shitboxen has faded too much.
    • It's a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind of information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game or stupid enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
