for sale skyline GT-R R32 BNR32 450HP
1- power steering pump has been changed for BCNR 33
2- Engine · Tomei Powered's complete engine, TRB 500
3- N1 block (24 U)
4- N 1 water pump
5- Adjustable cam gear made by Tomei
6- head bolt other reinforcement bolt
7- intake manifold G / K, adjustable fuel pressure regulator It is integrated
8- JUN oil pan baffle plate
9- trust made aluminum pulley kit
10- ECU, fuel pump are those belonging to TRB 500
11- Turbine is also included in TRB 500, made by Garrett (It is equivalent to HKS GT 2530 )
12- The plug comes with NGK Racing R 7436-8
13- intake HKS aluminum piping kit
14- exhaust Toyo stain exhaust manifold HKS extension NISMO front pipe for R 33 HKS metal catalyzer, super turbo muffler
15- Clutch HKS Twin plate (pull type) Nismo clutch hose
16- Watch only 5 speed OS Giken cross gear (0.826) T / M for embedded N1 Baffle Plate Built-in C's Quick Shift Embedded (With Normal)
17- LSD Rear Only Nismo GT-LSDPro 1.5way TT
18- Oil cooler HKS Element movement type
19- Radiator Nismo aluminum radiator
20- Intercooler ARC M073
21- · Nismo steering gear mount bush, E / G mount, M / T mount
22- rear suspension mounting bush differential mount bush, rear stabilizer bush · MCR rear member color
23- Body Reinforcement · Kansai Service Refresh Bar, Low Burres Bar, M / T Member Color · Nagisa Auto Athletic Support · Door Lack Rear Cross Bar · Cusco Fr Tower Bar, Tension Rod Bar
24- Nismo Rr Tower Bar
25- Brake · Fr R33 original Brembo calipers DIXCEL made FS rotor · Rr R33 original Brembo calipers Biot offset kit (φ322 R34 GTRN 1 size rotor) · cylinder stopper BNR34
26- . Leg swiveling · ZEAL function car height adjustment (Specification changed.) Fr: Swift 12K, Rr: Swift 10K straight winding Spring upper mount is replaced with aluminum rigid, Rr only for current type · Adjustable upper arm · nismo tension rod , Rear upper link (front and rear), rear A arm
27- Wheels CE28N 9.5 J-17 + 22
28- HKS EVC III, turbo timer
29- Kansai service E - TS controller 10
30- Recaro SP-G
31- Defi φ52 Racer gauge oil temperature gauge
32- Omori φ 52 boost total · Nismo 320 Km Speed meter
the price 26000USD
this car in United Arab Emirates, we can ship any place
To connect on the phone +971507374787
we have Whatsapp
my instagram: @speed4ever
  • Like 3
https://www.sau.com.au/forums/topic/475320-for-sale-skyline-bnr32-450hp-26000/
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
