R34 SKYLINE GT-T
1998 White, manual 180k kms
Carbon fibre/FRP Z Tune Vented bonnet, recently re painted (colour matched)
Z Tune style front bar
Heavy duty clutch
Lenso D1 Rims 18inch painted black
Slotted and drilled rotors
Hybrid electronic boost controller
Greddy colour infometer
Blitz electronic boost gauge with peak recall
Cross over piped front mount intercooler
GCH Hi flowed standard OP6 Turbo
Standard manifold
Driftworks thermostatic oil cooler
Nismo 2 way mechanical LSD
Neurothane  suspension bushes
Hardrace Adjustable Caster arms
Cusco Hicas removal kit
DGR adjustable coilovers
White line adjustable sway bars front and rear
1000cc injectors
Upgraded fuel pump
LED Dash lights
HID head lights
Blue LED under dash accent lighting connected to a switch.
Jenson double din touch screen head unit, linked to a revised camera.
Custom made Light duty removable towbar
Nistune, re-tuned by Mark at MRC Castle hill.
Z32 airflow meter
Larger aluminium radiator
Standard Nissan exhaust fitted at the moment,
But I have a full 3inch stainless steel Blitz Nur spec exhaust with high flow cat.
( this was removed to pass an EPA inspection ). This will go with the car.
Also have a turbosmart, plumb back blow off valve, but the standard Nissan one seems to be doing just fine.
DBA slotted rotors with TRW pads
Alarm and immobiliser fitted.
Freshly serviced, oil, filters, spark plugs.
Greddy magnetic sump plug
Always run on premium synthetic oils
Liqui-moly, most recently Penrite 10 tenths , Most importantly the engine oil was always up to temp before anything more than cruising.
The car is in above average condition, a few small imperfections, and wear can be seen. Still a lot better than some “immaculate” or “mint” cars I’ve seen.
The steering wheel looks pretty ordinary, there are a few cracks around the bottom of the front bar, a small carpark dent on the drivers door near the handle.
139F8B7B-A846-4EBC-8DC6-63D2BC6AFE42.thumb.jpeg.4680553707fe37f7e696cdf9ea4fa4ce.jpeg8920BBC2-1187-4C71-BFD6-F3754B12D2A9.thumb.jpeg.d7b95c97ee7996c4f689fed963a37226.jpeg09126D34-9FD3-49A1-A0C1-DC7D12639E90.thumb.jpeg.e24a37f9cddfb3626b5540fe81ec7ee3.jpegD8ED3A02-FA39-4A28-BE2E-17633C7532B4.thumb.jpeg.121227fb9bdc41422f5e7883442dda2f.jpeg734638B4-36F5-409A-96CE-004FF49A9795.thumb.jpeg.13a56131e5ebc31a68b35cadd9bdd54c.jpegCD40A3BB-5C57-467B-A24B-9D1C859D9FF1.thumb.jpeg.c8c200c94163934c24be2871d807d99a.jpeg5B818A80-27A7-45EC-9344-95626CD66943.thumb.jpeg.e9fd8be9e5bb64011194a8335d4032d3.jpeg55CD8CDA-4BC4-437B-B02F-E8F3F12A3169.thumb.jpeg.255a5a064a694b7fb94864a740268dfe.jpeg38AA066F-56F4-48E8-BA57-C2382CFAFC77.thumb.jpeg.cdc8966b5ef11d8280adf49bb1813ca6.jpeg4A8AAE6F-741A-4DE9-BC5C-AB35EA52A711.thumb.jpeg.b2545d5dff443486149901cf89fdcae1.jpeg50C1C611-D2AF-4D14-8BF8-7C27BEBE575B.thumb.jpeg.7887dec11222104c33a23898ede3bd1b.jpeg
$17,000.
Call or text Adam on 0426 46 50 50,
Car is located in western Sydney.
https://www.sau.com.au/forums/topic/475321-r34-gt-t-coupe-manual/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
