Evening all, just joined having been recommend by the UK Stagea FB page.
Currently drive a nugget of an 04 2.0 Forester XT, hopefully picking up an M35 this weekend.
Here to soak up some valuable Stagea knowledge, and help others where I can.
See you about...
https://www.sau.com.au/forums/topic/475339-greetings-from-the-uk/
See you about...
Welcome mate.
The UK has a few rare Skylines. Much of a scene there nowadays?
On 11/7/2018 at 10:31 PM, Robocop2310 said:
Welcome mate.
Thank you! I'm just getting into the Nissan scene. Deffo see more skylines than Stageas about though!
On 11/7/2018 at 11:24 PM, PranK said:
Welcome Tumble! Good luck in your search, you better post some pics when you pick it up! :)
Thanks PranK !Picked her up yesterday! Will start a build thread and add some there as I go :)
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
