Hey guys
trying to get some advice for where to go with problem solving on my stagea, its one of the dreaded 08/97 built cars that have an ecu they ran for only one month apparently.
pretty much the problem is the car is idle hunting badly running rich and rarely but sometimes stalling at idle and then under power it will stutter and cut out untill i clutch out taking load off.
The previous owner had it manual swapped from an auto and the issues started from there as i found from the mechanic who serviced it.
if someone could help with a pin out sheet or advice on which ecu to go with or if theres. Something i should replace i would much appreciate it.
Edited by Fridge_repair_man
https://www.sau.com.au/forums/topic/475353-manual-conversion-gone-wrong/
The most common ecu is the OV300 followed by the OV 301 so I take it you have an OV310? The problems you descibe are unlikely to be the fault of the ecu or the manual conversion as cars usually run fine with the auto ecu. I will attach a pinout which you could check against your ecu. if you really want to ditch the ecu you could fit a Link which would give you the tune-ability you will need if you are going to go for more power (bigger turbo, injectors etc).
Pinouts WGC34_Series_1_-_STAGEA_RB25DET_Auto_ECU_ translated.xls
R34 Pinouts with wire colours.ods
Pinouts R34_ecu.pdf
Pinouts R34_ecu.pdf
If not the ecu pins what would you suggest i look at, ive replaced alot of thing  and im running out of ideas
Try this;
https://www.sau.com.au/forums/topic/110431-diy-aac-valve-cleaning-idle-reset/
clean the afm and check the wiring and plug
replace the fuel filter
check fuel pressure ...new pump?
check that the CAS turns smoothly
I presume you have replaced the plugs and cleaned and possibly insulated the coils
New air filter
I agree it's unlikely to be the ECU that is the issue, although not impossible....what would be pretty much impossible is finding another one of those bloody ECUs to swap in.  As you've probably seen elsewhere my stagea is the same month and had troubles when I swapped to an aftermarket ECU because pin outs were different to the ones before and after.
I'm assuming the car is reasonably stock other than the manual conversion.  Having an auto ECU in a manual converted car will not cause an issue on it's own, the main difference is the atuo ECU has logic to cut timing when the auto is shifting for smoother shifts. Since you have a manual now the ECU never gets that signal so that function is not used.
The other thing about the auto ECU is that it might be less tolerant to mods, and that could be part of your issue depending on mods.  In earlier series like r32 and r33 the ECU was more accepting of extra boost/airflow, but in the later series (and I found this ECU in particular) was really unhappy even with boost at 10psi instead of 7 even on the standard turbo. Basically the map had a really narrow band where it runs at sensible air fuel ratios, and it goes mega rich and retards the timing heaps outside that with the intent of protecting the engine from whatever went wrong to take it off that narrow path.  Very rich running in particular can cause misfires alone, and can quickly foul spark plugs which will increase the issue.
So....if you are unmodified, check the usual skyline/stagea stuff like Bobby has posted above.
* Most likely reason for running rough and idle and stalling is an air leak in the intake after the air flow meter and before the inlet valves, or a dead or dying AFM. A good mechanic can do a smoke test to check and it would be a good idea to swap for another AFM and see if that helps
* Maybe run it on a dyno somewhere with monitoring of fuel pressure because by this age could be fuel filter, injectors clogged or leaking, fuel pump dying/losing flow at high pressure
* Coil packs / spark plugs / spark plug gap. Start by replacing with new plugs gapped to 0.8mm instead of standard. If that helps there is a problem in the ignition system so consider new coils or check the coil pack wiring and earth
* Have a compression test done, there could be a mechanical problem in the engine.
If the car is modified or running higher boost you need to get it on a dyno and find out if it is a rich running problem, and if so plan for an aftermarket ECU and some added expense getting wiring modified somewhat.  Sorry I don't have a wiring diagram or details of what was changed in my car, it was more than 10 years ago now. I know there were coil and air con issues but can't remember details.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
