First pic its the oem boost solenoid. Do you have some sort of boost controller installed?
Second one looks to be somekind of diy switch. Could be for anything really. Possibly a power switch for aftermarket gauges, lights or something like that. Only way to find out is to follow the wires
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891059
First picture is a boost solenoid which may have been connected some type of boost controller before it was unplugged.
Second photo is a on/off for something as others have said - if you want to find out take it out and then follow the wiring. My guess is it was for something boost related but has since been removed. Very stealthy to have it mounted by the door.
Third photo is a fire extinguisher holder. Most Skylines (all, if I’m not mistaken) came with portal fire extinguishers but most have been removed.
Cheers.
  • Confused 1
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891068
11 minutes ago, adey88 said:
2 hours ago, FedBpy2018 said:
Is this thing normal?
I believe that's for a flare (not fire extinguisher) as required by law in Japan.
Actually, now come to think of it...I think you correct. Then some people place fire extinguishers there but originally yes it was a small black flare.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891074
People don’t put fire extinguishers there because it will be hard to reach while in the drivers seat, usually it’s on the right hand side of the passenger foot well or under the drivers/passengers seat. Also the flares are red.
  • Like 2
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891079
Right, you are (photo of flare on same spot).
images?q=tbn:ANd9GcSvXAHjllvKPsvxpO5YHvo
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891081
Since you are not using the stock boost controller you must have an alternative. The simplest would be an R32 actuator. Trace back from your actuator to see where the line goes and you will find an aftermarket controller if fitted.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891090
I followed the wires from the actuator they lead inside the dash through the firewall and cant follow from there, this sunday im going to take the dash apart and find it, has anyone got a guide to do it? If it was a car i normally work on i could take it apart in less then 5 mins lol, im guess for this it will take a few hours to pull apart and put back
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891151
That's a factory boost solenoid with factory wires that will lead back to the factory ecu. Hardly worth chasing, certainly don't pull your dash apart to solve this non mystery.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891153
3 minutes ago, FedBpy2018 said:
So dont bother using it then?
Well, that depends on what other boost control you have.
Also, there is an obvious misunderstanding as to what terms is being used here.  The item in the photo is the boost control solenoid, as others have said.  The "actuator" referred to by Kiwi is not that solenoid.  He meant the actuator that is mounted on the turbo that pneumatically pushes on the wastegate lever.  Not the same thing at all....although, obviously, related.  All part of the boost control.  Anyway, there are no wires on the actuator.  There wires on the solenoid are as Ben said.  You should follow all advice given.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891157
From what i can see inside the car there is no other boost controller, also what causes a door window to tilt towords the inside of the car? Photos attached, the purple line on the window is the window hitting something on its way up so i dont use it but previous owner did, the first photo is what a owner had done to bypass the solenoid
Edited by FedBpy2018
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891163
Unless that's an RB20 actuator (and I can't be stuffed searching the part number to check).....then you have a whole 5 psi and your car should be as slow as all f**k.
The window is easy.  The stuff inside the door that keeps the window aligned (so, either the runner channels/rollers or the felt pads near the top) are stuffed.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891165
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
