Hey,
I've purchased a replacement set of bushings for the busted bushings (see pic) in my lower control arms in my 02 C35 (Specific model PV35 350gt8). I'm wondering if anyone can give me a rough idea of how much a standard mechanic will charge for the labour, what price would be a rip off and if anyone has a suggestion for a good mechanic in the Perth region?
Thanks
Take out the control arms yourself (easy job, 2 bolts each side = 15 minutes per side). Take the arm plus the new bushings to any half decent workshop and they can press in the new ones for bugger all $$$. Reinstall yourself. Profit.
Thanks for the replies. Thinking we'll attempt it ourselves first, got access to a workshop and tools, plus I don't know what state the rest of the suspension is in yet, I don't want to be conned into replacing things that aren't necessary.
I'll post some photos when we get under there, let me know what you guys think.
My parents run an engineering/hydraulics workshop so good chance they've got one. Quick question, I read the bolts need to be torqued at ride height, if so, does that mean the car needs to be on the ground?
I did mine on jacks, then drove the car for 80,000km (before its untimely demise) without any issues. Can't see any benefit/effect of torquing them on the ground.
Yes.  Or on a 4 post hoist, or any equivalent that has the car high enough for you to work under it, but with the weight carried on the wheels.
Um, it has to do with having the pivots in the orientation that they will be at in actual service, along with the load being passed through them being as per service.  If the wheels are hanging from the pivots, instead of the pivots holding up the weight of the car, then the loads in the bushes are nowhere near the same.
Ah ok cool, I just read something about the torque being off if not done at ride height.
Anybody in Perth feel like lending me a hand for a carton? ? Seriously though, would be really beneficial to have somebody who knows what they're doing help me get this sorted, I'd be happy to pay for your time ☺ There may be other issues that I and the guys helping me might miss etc...Really want to get it back on the road...Sat in it yesterday and just revved it a little...having car withdrawals lol
they really should be tightened and torqued up in their normal operating position, if you torque them up when there is no weight on the suspension, the rubber in the bushes will be permanently twisted when the vehicle weight is put back on the suspension.  Not as much as an issue with poly bushes as they can move, but rubber bushes are fixed to the inner and outer steel casing.
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
