Currently have annoying misfire problems. The engine is RB30neo, after taking car to reputable tuner he replaced cas with secondhand cas , a coilpack, std fuel reg, fuel filter and said the fuel injectors are dirty and fuel filter was blocked.  So he road tuned car and said its better now.
Original issue was it running like a wrx for first 10mins, after that it was a rocket.
So now after it being at the workshop, it still starts like a wrx and now it has a strong misfire at 4k, right at the point it used to start breaking traction.
So i started it up and pulled one coil out at a time, cyl 3 and 5 not firing.  These coilpacks are brand new, have replaced them twice now.
So my question is what can cause cyl 3 and 5 to randomly not fire? Or are these splitfire coils fake copies?
https://www.sau.com.au/forums/topic/475431-misfire-problems/
  On 20/11/2018 at 1:13 AM, iruvyouskyrine said:
1. get a new tuner
2. never seen fake splitfires
3.get your multimeter out and start continuity and voltage checking. Also inspect loom for damage.
Expand
Yep that workshop gone to shit for sure.. not happy..
This morning i tried again, and cyl 3 and 5 dead, so i put 2 old coilpacks in and she ran sweet except heavy breakdown under load later when was hot.
So whats the chances of 3 brand new coilpacks failing on a cold start?
Loom is brand new from kudos, plugs new also..
What about the cas or ecu, can they play these kind of games?
I dont really have a clue about multimeter testing.
CAS "might" be cooked and the ECU is unable to determine a home signal, i.e. 1x full revolution of the CAS to determine TDC.
This could affect your car starting, however without using any tools it might be hard to diagnose.
Maybe try record your PowerFC hand controller with a GoPro or phone and see if there's a RPM when the CAS is rotated OR the car is cranked.
Expand
The coilpack harness might be new but i bet the main engine loom is not. I would start looking where is passes the exhaust, where it passes through the firewall and around the ECU header plug.
Youtube how to continuity test with a multimeter, its an excellent skill to have and difficulty level is 2/10.
  On 21/11/2018 at 7:58 AM, mr_rbman said:
Sounds like a similar issue i've had...
You running a Z32?!
Expand
Yep a z32, today again cyl 5 so i switched it with cyl 6 coil and just like that all 6 firing...
Will start looking into the multimeter idea and the cas test..
  On 22/11/2018 at 11:49 PM, AngryRB said:
Is this plug helping? Last set was a BKR7E that had a split in the electrode
Expand
That's a hot plug man, no way would I use that in a higher boost application (or any boost for that matter)
  • Like 1
Expand
Expand
Is it just me or is that plug gap huuuuuge?!?!?!
Expand
The 11 in the number will refer to 1.1mm gap, so yeah that big gap would explain the break down under power.
  • 2 months later...
Small update, i changed the plugs back to BKR7E and she has all the power back with no misfire's...
The issue still remains, that is i start it and its on 5 cylinders until i drive up the road and load it up in second gear , then it seems to clear up and runs perfect.. except for it usual jerkiness on very light throttles which i assume is the camshafts or maybe tailshaft slop..
So what could it be that clears up with some load applied, could injectors be need8ng cleaned after 10k and using ethanol? Diesnt ethanol clean shit???
Tuners explains it as it must be dirty injectors but after he put shit plugs in not sure if hes right...
Coolant is not going down and fuel economy is good, power is good, its just cold start on 5cylinders till loaded up.
Edited by AngryRB
    • Yes, I know馃檮 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole馃ぃ
    • You鈥檒l be very upset when you bust that too not to mention the gearing totally sucks. Don鈥檛 do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30掳 silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30掳 silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
