@steve85 - out of interest, which shop is on the compliance plate? Mine was complied in Feb 2000, was interested to know.
This was brought in with quite a few others (assuming my paperwork is correct). There should be around 5 or 6 clean R33s that were complied in short period around late 99 or early 2000.20180927_Steve%20Wood%201997%20Nissan%20Skyline%20GTR%20R33%2001.jpg
OK, mine was brought in Feb/2000 by AVO Turbo
No paperwork exists from this timeframe (I asked them) - and its too early for the JOC records.
When I say paper work i mean the notes that came with the car. The buyer took notes on the dealers inventory before he decided which car to buy.
Another christmas holiday down. Another poor effort getting the cars out for a run. Neither myself, nor my wife managed to have enough time to take either car out.
The new GPS/Tracking system is draining the battery and i only have a single charger between three cars.
Killed the battery in the Silver GTR good. In my defense, it looks to be old and is a small capacity battery.
I'm keeping an eye on the internet for decent priced chargers.20181223_144024.jpg20181223_144013.jpg20181223_143902.jpg
Hah, that old chestnut.
I picked up a Ctek MX5.0 cheap at Repco of all places, good unit and came with 2 sets of comfort leads for quick changing between cars.
You could also look at the cheap solar cigarette lighter trickle chargers.
  • Like 1
After killing (well, that's what I thought) two batteries in my now-sold R34 due to underuse I bit the bullet and bought a Projecta Intelli-Charge IC1000 (10 Amp, 7-Stage) charger.
The second battery, which failed to crank after 48h+ on a Supercheapie charger, was promptly revived by the Projecta and ran beautifully since.
The Projecta is not cheap at around $200 but I can recommend it. It's also smaller than what appears in the online photos so easy to pack away when not in use.
  • Like 2
To save this one, i shoved 100+ Watts into it from a power supply i have lying around. I seem to have saved it, but after being so horribly drained, I can't imagine it will be all that wonderful from now on.
I also add, i know this isn't what you are supposed to do with batteries, but, I was desperate.
I have this, except that the cars are jerks and I think the Silver GTRs battery is a little less capable than that in the LM or my wagon.
I'm looking for a second CTEK... so much effort for cars that don't move. (rolls eyes).
1 hour ago, ActionDan said:
Mid spec ctek and up will have a rejuvenate setting that seems to work well when I was killing batteries in the Silvia.
100%. After I had jammed as many amps as I could to bring the voltage up, I popped it onto the CTEK and let it run the conditioning cycle a couple of times.
Worked ok from what i can tell. ?
2 minutes ago, junkie said:
Get an optima yellow top once this one dies. they can handle many more deep discharges than any normal lead acid battery. Mine gave up only recently after 9 years of service and going flat 20+ times
Thanks for the tip. Saves me doing the research myself. :)
  • 2 months later...
For those of you who mentioned the lack of cleanliness (hehe) in the video that I created for this car, here are some pictures post wash;
20190216_202545.thumb.jpg.84337f6b6e9c17f7c95a07a2f116bb0a.jpg20190216_202647.thumb.jpg.e712c116ac63244fc29cd4d51d0ef8bf.jpg20190216_204032.thumb.jpg.bddc65c5daa196f4e27d414057554102.jpg20190216_202456.thumb.jpg.00d29aee16e900f4439502e423dea798.jpg20190216_202514.thumb.jpg.5939ac1a0cfe1c0a91777de98be5e96e.jpg20190216_202532.thumb.jpg.de234fa80b65bf771ce6e261e15a387b.jpg
Also as is pretty evident, the car hasn't gone anywhere yet. Still haven't even put the plates on it. All that's happened is it's killed a battery, so I have taken apart the boot and have put a charger in. You've probably all seen these images already. But i know you're all suckers for images, and who am I to deny you! :)
Edited by Steve85
Just get a small solar panel to keep the battery charged and a regulator if you are paranoid.  Assuming you get some actual sun every now and then it works a treat.  For all of $50.
  • Like 1
Solid advice and a cheap solution to my problem. Unfortunatly I did not do this though. [emoji848] Found a reasonbly priced ctek charger. Purchased that and put it onto the battery.
Gotta love plug in cars! [emoji16]
  • 1 month later...
Update on the KR4 R33. We took the car out to the 50th Anniversary Cruise arranged through GT Car Club and V-Spec Performance. My wife drove it down to V-Spec in Blackburn, where the car received considerable attention (a lot more than my car). It ran beautifully and had no problems.
The best part was there was also another completely stock R33 GTR there in Silver. I spoke to the owner briefly, then missed him at the other end. The other stock R33 had about 55k kms on it (IIRC). I was so disappointed to have not met up with him again.
The KR4 GTR (which it is called in our house) added an additional 250kms to the odometer. It's now 100kms under 10000kms in total (where it will lose all value I assume -jk).
Here are some images of the event:
20190414_090612.thumb.jpg.d35e12ddee02f2f633c155c79ee81801.jpg20190414_091300.thumb.jpg.d41f47ffdfefa148d3bf99b1f2d63382.jpg20190414_105119.thumb.jpg.8aab795fabb0dd1c9fd4c28981345dae.jpg20190414_105155.thumb.jpg.dfbd358aa5f766f8ff6cc2f3726e1873.jpg20190414_132300.thumb.jpg.9c7291f1902cf2100643870cd4d9ee89.jpg20190414_145654.thumb.jpg.38882d56d6f5aaad08738a7309fb650a.jpg
Edited by Steve85
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
