Guys,
Selling my long term project of 10 years which I've finally concluded I will never finish and have lost all motivation to finish aside there is very little to do to be complete - Life just got in the way.
1990 HCR32
Engine:
RB20DET - Stroked to 2438cc
RB26 GTR Crank
RB26 Eagle H-Beam Forged Rods
84mm Wiseco Forged Pistons
Tomei 84mm 1.25mm Head Gasket
ACL Bearings
ARP Head Studs
Port and Polish
Tomei Solid Lifter conversion
Tomei 272 9.25mm Cams
HKS CAM Gears
Nitto Oil Pump
Crank + Cam Trigger setup
Hypertune Custom Intake Manifold
Hypertune 90mm Throttle Body
Bosch 980cc Injectors
Billet Fuel Rail
High Mount turbo manifold
3582 JP Turbo Ceramic Ball Bearing Turbo
SpitFire Coil Packs
Body:
Black Respray
Coilovers
Half Cage
18" Wheels (New Rubber required 10+ years old)
Front Mount Intercooler
50mm Alloy Radiator
Blitz Fibreglass ADR approved bonnet
Electrical:
Haltech PS2000 ECU
Haltech Wide Band
IQ3 Digital Dash
zLeds Rear tail lights
Battery Relocation to boot
Fuel Pressure Sensor
Oil Pressure Sensor
Walbro Fuel Pump
After Market Fuel Level Pickup
MAP Sensor
Crank + Cam Hall Effect sensors
Flex Fuel Sensor Wiring
Wiring Specialties Wiring Hardness
What's left to do? Really not much,
- Set base timing on ECU for Crank trigger setup.
- Mount Fuel Pressure Regulator
- Mount Catch
- Setup Fuel Level Input for Haltech
- Tighten bolts on half cage
- Interior tidy up (Cars been sitting in the garage for 10+ years)
- Tune
- Enjoy
Located in 4300 QLD - Pickup only, Only genuine interest and obviously no joy riders as it needs a tune. Pictures will be supplied on request only.
Edited by murrayis
https://www.sau.com.au/forums/topic/475450-fs-1990-r32-gtst-15000ono/
  • 3 months later...
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
