Update, compression tested all cylinders, all consistent across the board except for having absolutely no compression in cyl 3.
Stuck a camera down the bore and turned the crank manually, and it can be seen that one of the intake valves does not seat back into place properly as the valves on other bores do. However clearances are totally within spec.
