WAG.00N Posted November 25, 2018 Share Posted November 25, 2018 Have had this car for nearly 10 years and when we bought it is was standard. Engine / engine bay Approx 15,000kms after reco 10 years ago. Mahle forged pistons Cometic head gasket Oil pump mod ASR baffle/doored sump Oil cooler Power steer cooler PWR radiator and spal fan Motec M84 cost $3000 M & W CID ignition cost $1100 Garrett 30/76 with .92 rear housing Modified factory intake with Ford falcon throttle body 840cc sard injectors. Intank walbro pump which feeds surge tank with 2 fuel filters and a Bosch Motorsport 044 pump for main fuel supply Insight Motorsport Custom Cam’s and adjustable cam gears. Titanium retainers and double valve springs. Rebuild rb25 gearbox Makes 330rwkw (440hp) @ 17psi on 98 fuel We picked up 70kw on th same boost with the cam upgrade. I haven’t run more than 17psi as with the tyres size on the race track it’s hard enough to get the power down. The engine, turbo, pistons and cooling system would definitely handle more power especially with the good ECU and Ignition system it has. Suspension/Brakes/chassis S13 front suspension conversion Fabricated brackets for adjustable caster rods Ksport coilovers all round Ksport brakes Fronts 8 pistion 365mm rotors Rears 6 piston 330mm rotors Solid rear subframes bushes Hicas deleted and vanes removed from pump Hyundai tie rod ends to allow more thread in tie rod. Rebuilt r200 diff with extra clutch plates. Works great! Wheel alignment specs Front 3.5 degree neg 7 degree caster 3mm total toe out Rear 2 degree neg 0mm toe Body and interior R31 house front bar and lip Forget the name of the side skirts and rear skirt Has good paint however over the years of close racing it has stone chips on the front end. But still present very well. six point cage. All tig welded. Back seats don’t fit but have been stuffed back in to looks like it’s factory. 2 bride seats. Has engineers report however I don’t know where it is anymore and it didn’t include the cage and brakes. I never planned on selling this car and was working towards making it a race car only. It’s still has full rego and plates are included. please call or text 0415292220. Not really interested in swaps either Tags; GTR r32 r31 r33 v8 Holden ford skyline e85 Nismo Vspec Mazda AFFC0CC6-37F9-47F7-A221-BF08533944DA.MOV 2 Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/ Share on other sites More sharing options...
The Bogan Posted November 25, 2018 Share Posted November 25, 2018 How much for this classic beastie? Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/#findComment-7892003 Share on other sites More sharing options...
WAG.00N Posted November 25, 2018 Author Share Posted November 25, 2018 $34,000 cheers Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/#findComment-7892004 Share on other sites More sharing options...
BlueThirtyFour Posted November 28, 2018 Share Posted November 28, 2018 Beautiful car mate, good luck with the sale. Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/#findComment-7892265 Share on other sites More sharing options...
WAG.00N Posted November 28, 2018 Author Share Posted November 28, 2018 Cheers mate! F729B841-CA4B-4763-8288-30E51F33F56D.mov Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/#findComment-7892268 Share on other sites More sharing options...
WAG.00N Posted December 10, 2018 Author Share Posted December 10, 2018 Price on guntree is now $30,000. And sorry but still no swaps. Cheers Link to comment https://www.sau.com.au/forums/topic/475468-1988-hr31-rb25-streetrace-330kw-17psi/#findComment-7893446 Share on other sites More sharing options...
