Shuuuu,
So here goes, built motor, everything pretty much new, however re-used the OEM NEO oil pump, which similar to a GT-R N1 pump.
With the pump, modified it and installed a set of Spool Import Billet Oil Pump gears and installed the matching collar to suit from Spool as well.
It provides good oil pressure, cold start up about 4 bar on idle (according to my Haltech pressure sensor & the dash shows about the same too)
Oil pressure increase as RPM increases and appears the pressure relief valve works corectly too and plateaus about 8~9bar with higher RPM.
Once warm, I get about 1.8bar of oil pressure on idle with Penrite 10/tenths 15W50.
Car is running a JHH oil relocation block, -10AN lines to a GREX relocation block and into a 25 Row Setrab oil cooler with a Z422 Oil Filter (has anti-drain back)
Now the problem, it takes a good 15 seconds to build oil pressure when you 1st start the car when cold OR when it has been sitting for more than 10 minutes
I've changed the oil filter just to be safe, still same thing.
Lastly, this has only started to happen after the skid pan day... If I did crack the gears, the car would simply just stop building oil pressure but it's still making pressure.
So this has lead to think maybe the oil pump housing itself is damaged?
Perhaps more likely that the external oil plumbing (in particular the anti-drainback valve) has suffered a failure and letting the oil out of the loop?  Perhaps your investigation path would be to pull that loop apart when it's cold and/or possibly drained back and see if it looks more empty than it should be.
Slightly off topic but maybe relevant.
My RB30 does this also, on a cold start its substantially worse. engine ticks loudly for ~10-12 seconds until oil pressure builds and then goes nice a quiet. I don't have an oil pressure gauge in my car however.
RB30E with 320,000km on it when i got it, now at 350,000km @ 380kw
Completely standard untouched original nissan RB30E oil pump with shim in relief valve to bump up pressure.
Not running any form of oil cooling either.
  • Like 2
The anti drain back is part of the Z442 design, might start pulling off hoses as recommended and see if there are issues around that.
Worse case scenarios:
  • sump pick up is cracked/broken and sucking in some air.. was a modified item by ASR
  • Oil pump housing is cracked, I did re-use the OEM N1 oil pump housing and put in Spool billet gears
  • Collar tolerence (if any) destroyed shit after heaps of limiter
Well, it is end of year - a few days under the car to pull off the subframe, sump using an engine brace.
Sigh!
  • 1 month later...
Just an update (for those wondering and for future people with the same issue or so).
Turns out the oil pump gears and housing were heavily scored and also the gears pitted from either cavitation OR foreign material being ingested.
Removing the sump showed no signs of metal or debris, pick up was clean and oil filter (although not taken apart) appeared clean inside as well. Was unable to pick up on any foreign debris which alludes me to thinking there was some form of tolerance using the billet gears in an old housing and/or some for of cavitation which destroyed the gears and then the housing.
A new N1 pump has been purchased and now waiting on Spool Imports to re-open and a new set of gears will go back on. Hopefully this will solve the issue(s).
And during this time, I decided to put a bigger turbo on too - old setup has been removed (manifold, gate, lines, screamer are sold - everything else still available)
20190104_180211.thumb.jpg.3fa73948835bb16835f9a7070d39531b.jpg20190104_180149.thumb.jpg.fd24f486b5c0cafd43ea8827b519130a.jpg20190104_180119.thumb.jpg.e86cf761212fd0698f47f7549cca8b88.jpg
  • Sad 1
23 hours ago, Dose Pipe Sutututu said:
The back face of the gears looks like it has taken a hammering, i don't really know about this stuff but my gut says they shouldn't be that worn
1 hour ago, NEO25T said:
Probably referring to the thrust bearing, is the crank sliding forward when clutch is pressed
Ahh, no idea to be honest but with the 1000+ or so clutch dumps, limiter bashing could be a possibility?
16 minutes ago, NEO25T said:
Easy to check while its apart, if the crank is hungry it will try eat the new pump too and u dont want that
swap for a F30 335i BMW and I'll throw in a tool chest too
    • Thanks Pac!   I will reach out to them!
    • Yes, but 2 things of the top of my head, 1. Legalities of nitrous on a street car. 2. No chop chop. I fully understand that there's much cheaper ways to make power, and whilst a wet 50 shot is fairly cheap to install, bottle fills are expensive, and bottles always need to be refilled, and nitrous also has its own inherent issues with reliability, and tuning, from my experience of others using nitrous, it doesn't take alot to lunch a engine real quick if something goes slightly wrong when spraying, if I wanted a big chunk of additional powers, a spooly boy would make alot more sense, disregarding the additional engineering, supporting mods and other logistical issues of sticking a spooly boy on a car that came naturally aspirated from factory  In the end I'm not racing for sheep stations, and I don't really care if people make more power, or are faster than me, or spend less, or more than me, the only thing the car needs to do is drive around and make me smile, which it is doing now Really, I just want a shiny new intake to look at when I'm cleaning the engine bay, and of course, some more induction doorts, and maybe even that 5kw for that elusive 200hp cherry on top that I might get If the FAB9 intake plenum, TB and air filter box thing doesn't eventuate for whatever reason, Plasmaman do one, not as fancy looking, and a fair chunk of more cash is required when including the TB and other bits and pieces that are required to install it, but, it is another option that is available to me if FAB9 one does fall down (but I really, really.....really, want the FAB9 one though) TL;DR. You want what you want
    • Been so long since I have been here,seeing SDU is dead. I had that problem on my gtr in 2006 but luckily there was no engine damage,it was inspected by Hytech Engines,race bearings and extended crank collar put in and that was about it. Hopefully yours is sorted now.
    • Would it not be cheaper to just spray nitrous?
