I have a r33 gtst ( auto ) and it’s stock apart from a front mount intercooler, carback exhaust and pod filter.
It runs fine up until 6psi but once it goes over 6psi the car cuts out and jolts foward ect . Can’t figure out if it’s a boost cut or fuel cut or why it’s happening.
Currently running 7psi with a manual boost tee
Any ideas what it could be? Have checked the afm and it seems fine, vacuum lines are fine and can’t find any boost leaks ( it holds boost as long as it’s less than 6psi )
im thinking it might be coilpacks, spark plugs or tps but don’t really want to start buying parts until I know what I need so I don’t replace stuff that isn’t broken
https://www.sau.com.au/forums/topic/475496-r33cutting-out-at-7psi/
How high in the rev rang do you hit 6psi before this happens?
Do you have any aftermarket ECU?
Read this topic.
https://www.sau.com.au/forums/topic/336073-r33-rb25det-cutting-out-on-boost/
Read this topic.
The tacho doesn’t work but I’d say it’s somewhere around 4-5k revs
stock ecu
Update: have changed spark plugs ( regapped to 0.9 ) and it seems to have stopped the boost cut but now it’s misfiring under load, changed the coilpacks too and didn’t change anything.
Is fine if I drive really quiet but if I put my foot anymore than half way down it just sits there farting . Any ideas what could be causing it? Will have a look at the fuel pressure but I’m thinking it’s something to do with the plugs as it got worse when I changed the spark plugs
wouldn't surprise me if both sets are cooked... Borrow set of decent coils that aren't yellow or red in colour.
If S1 check ignitor/swap it AND check the ignition harness (clean or replace or hit it with WD40)
if S2 check the ignition harness (clean or replace or hit it with WD40)
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
