1 hour ago, mlr said:
Bin the front diff, I had 380ish RWD, that was pretty fun.....while it lasted.......
You can relive that dream, just buy mine. I'll tune it before you take ownership :)
Should pump out a good 430kW or more, great for Powercruise
  • Haha 1
Maybe, at the end of the year, if it turns into a mint 1970's Toyota Crown, I reckon a Crown with a old 2J would be sweet.
Or a Barra in it, to keep my inner bogan happy.
I approve of the Barra.
Why go an old engine that's missing a whole litre of displacement?
  • Like 1
Hey lads brasil trip has been pretty damn crazy so far and found myself in a favela for a good week...now in santa Teresa at a real nice pad and heading out for a boat party tonight. Military police stormed the favela Saturday morning and gunfire for a good 5-6 hours. They were back at it again on sunday morning just after I left on a motorbike.
So anyway GTR made 360awkw with 20psi in the low end , falling off to 17psi in the top end. Scott thought might be the gates holding it back. Anyway, looks like this motor makes grunt & should keep me entertained !!
  • Like 2
Might be the best -7 result seen here?
The head will play a big part and will also be why the boost tapers off up high, that's a sure sign the turbos are not able to keep up wit hthe head flow.
More than enough for you for now, don't kill yourself, here or over there ;)
  • Like 1
  • Thanks 1
Interesting dan.... yes I do know the head was ported and polished, I think 360 is probably pushing the car as far as it can go without major upgrades like sequentials and diffs etc, should be fun!
A Quaife front diff should come in the passenger seat of every GTR. One of the best (and relatively cheap) mods you can do to these dinosaurs. You think you can get on the power early now Benny... get one of those in and giggle. ?
The egine, box, and rear diff will all comfortably handle 360rwkw. Turbos won't like it though and as Piggaz said, the front diff may not be happy if you are pushing the car often, definitely avoid 4wd donuts.
The rest of it will be quite happy there, with the exception of cooling as the twins, being pushed hard, will be quite hot so you would want to keep a close eye on intake temps and EGTs just for safety. Will be fine for the street unless you Fast and Furious everywhere, but you would want to limit consecutive hotlaps at the track (though with the current ambients you will get away with it for a while).
Enjoy :)
Dan I thought 20-17psi would be quite comfortable for the twins ? Piggaz if I had the money I would, at least I’m one carton of corona richer now...lol
anyway dan will keep in mind, and I’m not planning to track the car btw...no way do I want to risk binning it. Will take it easy and learn the car...
  • Like 1
You're confusing manifold pressure with actual turbine flow.
All "boost" tells you, on your guage, is what pressure is in the manifold above atmospheric.
It doesn't tell you how much lb/ft per min the turbo is actually flowing or how hard it's working to get there, thats' what compressor maps are for.
This is why EFRs like turbine wheel speed sensors as they are a bit touchy with over speeding.
A setup measuring 20psi on -7s with big cams will have the turbos working MUCH harder to maintain that 20psi in the manifold as the cams are flowing all that air out much faster than a car with stock cams which can keep manifold pressure up easily as the head can't flow it out. A good sign the turbos are well and truely overwoorked is big boost taper in the upper RPM, turbos simply cannot keep up so they are effectively maxed out, pushing more hot air. If your turbos are in a safer range they will be able to maintain boost to redline, they are not being out flowed by everhthing else.
Which is why people who get hung up on how much "boost" a car is running to make a given power are idiots, because wuthout knowing what turbo is on the car and what flow potential the setup has, it actually means SFA.
Edited by ActionDan
  • Like 4
Without cam gears and on a good flowing head it will have cost you some "boost" response, as in how high and how early a boost gauge reads, but that doesn't mean it's lost you on road response. You may well find it similar up to say 60-90km/h but beyond that the difference will be stark.
As above the head is just flowing out everythhing the turbos can throw at it. so it will be making as much power as the turbos can make as fast as they can allow it to be made.
If you want to improve turbo response, as in get them spinning faster sooner, you want good manifolds and pods, cam gears, and good intake piping.You're chasing 5-8% though realistically.
My car had the cast N1 manifolds which I found good, a nicely divided y pipe, which is proven to help, and any dash setup with decent boost should be on pods, we picked up 14rwkw by switching to big pods alone at similar power levels to where you are now. Don't beleive all the BS about the stock airbox being fine, at this power it's a restriction end of story.
That was with -9s which are a touch bigger and slower, but have higher compressor flow.
Edited by ActionDan
21 minutes ago, BakemonoRicer said:
Nice information Dan, makes sense....
im really interested to see how “responsive” the car feels compared to Paul’s EFR setup
A good comparison would be to my poverty poor person 2.5L spec single GTX3576R Gen 2 setup.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
