Chasing up a dyno sheet so we can do a little more analysis.
reality is I need stronger wastegates, but the car is just a response monster and it pulls like a freight train, I really don’t need the extra power just yet...especially when a C63 AMG couldn’t hold a candle to this don mega build....
1 hour ago, BakemonoRicer said:
Ben, yes Nismo R1 turbos on the car.
Everyone says they're akin to -7's but that makes no sense, I'm making 30kw more than what people estimated.
They certainly didn't let the Nissan out in this build Benny, because they built it with mostly stock engine components. ProSTOCK build. Even stock ECU ?‍♂️
  • Like 1
Well they put the fruit in the head. But I wish the bottom end was more fruity...
I'm suprised the owner didn't pay the little bit extra to run a set of forged rods......
Scott did laugh at the tune. The japs just love to throw a lot of fuel into it and be done with it.
That's about normal boost response for those size of turbos I thought? Especially when you have a half decent head. Remember manifold pressure does not equal lb/min of flow, it just means the turbos have pressurised the intake to that level. What's more important is rear wheel torque at 3900pm or wherever you're wanting to measure from.
My head was stock, but I had cams and gears and  it made about 20psi at 38-3900 rpm on it's way to 24-25psi, which it almost held to redline. As per my opther comments, the turbos were at their limit and being outflowed, just like yours (mine were newer spec -9s with the better centre cartridge).
Traffic light grand prix is fun, just don't blow 3rd :D
785nm of torque mate.
Don't want to take anything away from the result but it aint 785nm. Dyno was not set to derived torque which is the accurate at wheel reading on mainlines. Its more like 550-570nm which is still pretty stout.
You absolutely sure they are Nismo R1 then ? Output of over 350kw at only 20psi on 98ron seems very high does it not ? Also can you tell me how is R1 different than -7 turbos ? The specs supplied look identical to me. If I am missing something enlighten me as I am curious. Also your derived torque is on the bottom graph of your dyno sheet which is clearly under 600Nm as mentioned.
Nismo R1 Turbo: (Specs from RHD Japan)
Compressor Housing: T3 (A/R 0.42)
Compressor Wheel: T3 (Trim 55)
Bearing: Ball Bearing
Turbine Housing: T25 (A/R 0.64)
Turbine Wheel: GT25 (Trim 62)
Max. efficiency: 73%
Max. air pressure ratio (at boost pressure): 103% (1.35kg/cm2)
Garrett 707160-7 Turbo: (specs from Garrett)
Compressor Wheel: T3 (Trim 55) - Ind: 44.5mm - Exd: 60.0mm
Turbine Wheel: GT25 (Trim 62) - Wheel Dia: 53.8mm
As abov Benny, Derived Torque is different.
Here's an earlier graph before we finished tuning the car (it only ended up going to 380) and as you can see, and knowing the setup, there's no way it was making a genuine 1000Nm lol
It was "zippy" but I wouldn't have called it a torque monster, it was only a 2.6 in the end.
am i missing something, it says derived torque on the dyno sheet?
yeah that's right it does show derived torque, just not at 785nm . Dunno where 785nm come from as the derived torque graph clearly shows increments of 50nm vertical blocks, and is labelled as such with 200 at 4th block, 400 at 8th block and has 11 blocks shown. So just under top of 11th block is about 540nm, similar to around what admS15 mentioned. I'm still intrigued at the 356.4kw at wheels on 20psi with 98. I have GT-SS turbos on my 33 which are almost the same turbo as -7 / R1 except with a larger compressor trim of 56 (vs R1 with 55 trim) and I can't get near that.
Usually it dynos at 310 - 330kw on 98ron at 22psi. Runs mid 11s at anywhere between 116 and 120mph.
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
