26 minutes ago, IMACUL8 said:
Awesome Benny - love it!
 Thanks mate, good to see you're still keeping an eye on the build!!
Interestingly, the boost controller read 729ps, which must have been before the Prostock build.
The boost controller is now being chucked in the bin in lieu of a MAC VALVE
I can only assume the owner eventually sold it as he realised not having that much power wasn't for him.
I think down the road, we'll all be seeing a big EFR strapped to this lead sled.
Of course - haven't been around much lately - got some work stuff I'm dealing with - but I'm subscribed to your thread as I love the car.....
I'll be posting soon - have a potential project in the garage (car that I imported when I got mine for a guy that has come back to me) ;)
Can't keep both ... so we'll see what happens....
Hmmmm... I wonder if this could be the Bayside Blue Auto Select BNR34.......
HOW COOL DUDE!
Just now, BakemonoRicer said:
Still wish you had of sold me your S3 KR4 GT-R.
I would of saved money compared to the white polar bear LOL
Not for what you wanted to pay ;) ??
  • Haha 1
TRP Rigoli have finished working their magic, the don mega fuel system full of their custom bits is done & so is their custom crank trigger setup.
This should pepper the car nicely ready for EFR life down the track....
  • Like 2
Fuel system and crank trigger bits look good, I also thought that looked like an angle grinder job lol
What's up with all the filth and surface rust in your bay? Consider removing engine when you do the turbo swap and cleaning it all up. will lift the car a lot.
Slideshow was severely lacking Benny, no dyno runs, no drive bys, no tacho hitting red line etc. Actually... no video content at all 0_0
Image result for son i am disappoint
I was talking about the pic that shows the holes coming through near the subframe but somehow thought that was an engine bay shot? WTF lol
What's the plan for the surface rust underneath gonna clean/paint it all up? Would look amazing done.
Are they actual bulk head fittings or was there just a hole cut through the sheet metal?
Lol hmmm No plans to address surface rust there. If I was buying a car I’d rather see it....As soon as something gets painted over I would think the worst.
I need to bring the car into the 21st century with more mechanical mods first anyway. Despite the fact the car hasn’t been tuned yet, I’m already saving my pennies for an EFR8374 or EFR8474 setup.
I also thought Dan had lost his mind...
The surface rust isn't bad, but i'd be keeping an eye on it, just in cases.
^^^^Every single GTR owner ever. ?
The longer you leave surface rust the longer it gets the chance to become deep rust.
Get it cleaned up, painted over, and seal the metal from the elements to prevent further rust.
It also concerns me, you said this was all rebuilt in 2016, yet there is surface rust in a few pictures underneath it.
My POS has less surface rust under it and it sat in a field, on a farm, for the past 2 years, and also went 1.8M under water in a flood during that time, not to mention just sitting around for years. I'm wondering what the rebuild hid or more so, it's life after the rebuild. Crazy salt roads?
  • Like 1
  • Haha 1
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
