Howdy fellas. I have an issue:
TL;DR - 34 GT - Turbo & manual converted (Speedo was working) - Installed 34 GTT motor and loom - Replace ECU & Tuned - Now no speedo. Checked wires from sender & reversed. Checked fuses in drivers footwell (trip metre fuse in drivers footwell). Only other change was the *Anti Skid Control* box has been removed.
Send help please: Unsure of where to go next.
Long story -
Bought car, already manual converted. Replaced motor with GTT motor and motor loom (loom all the way to ECU plug). The plugs didn’t match the Anti skid control so I’ve ordered one from a GTT but I don’t think that will fix it. I investigated the speed sender and signal seems good. Unsure of where to go next.
Update** Now suspect maybe gearbox loom or earth isn’t quite right? Maybe it came look/dislodged in removing the motor?
I have trawled the hell out of Skyline Owners and SAU before someone links an article there.
https://www.sau.com.au/forums/topic/475507-r34-speedo-issue-send-help/
I have to plead a little ignorance of what should have been on your car in its original state.....but it is my gut feeling that the NA auto R34s had the speed sender on the diff nose, not the gearbox.  I might be wrong, but it is something to consider.
The RB25DET's manual gearbox speedo sender creates a +/- 1V signal (essentially an AC voltage), the frequency of which varies with speed.  The speedo head reads this and converts it to the 0-5V square wave PWM signal that gets put out onto the speed signal bus (which goes to the ECU/TCU, the ABS/TCS & HICAS CU).  All of those CUs are only receivers on the speed signal bus.  None of them create the speed signal.  Any one of them can be missing completely and the speed signal should still be available.  So long as the speedo head is still doing its job.
The only wires you have to worry about are the 2 wires that run from the speed sender to the speedo.  There is no power (car battery 12V, no earth) involved.  Just the connection between sender and speedo.  of course, the speedo is separately powered off the dash.
It is just possible that the diff mounted speed senders create a different type/quality signal from the gearbox ones and that might explain the speedo head's inability to read it.
There are other alternatives.  The speed signal might be good, the speedo might be good (in terms of receiving the original speed signal and transmitting the square wave version out on the bus.....but the head might have simply died as a coincidence.  Unlikely -- coincidences are to be suspected.  But possible.  A worthwhile test will be to put a scan tool onto the car and take it for a drive.  See if the speed signal is visible from the ECU.
As stated in original, speed was working with manual conversion before hand. Only since removing old motor and putting in GTT motor has issue occurred.
Aftermarket ECU is installed now as well so diags won't help.
Edited by R34GTTBoi
  • 3 months later...
  • 1 year later...
On 13/03/2019 at 8:34 AM, R34GTTBoi said:
Ended up being the wire to the dash - ran one manually and we were good to go.
Im having same issue after replacing motor. No rpm, speedo and faulty temp. Where did you run a wire to and from? Think this might solve one of my issues. Cheers
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
