Hi all, I have a Stagea 260RS S2 , and am grateful for being allowed on this forum, I live in the UK but need the help from you guys as there are not may Stagea's in the UK and from what I have been told only 1 series 2 260RS :)
I have rebuilt a few RB25's in my time so hopefully will have some positive input in the future
  • Like 2
https://www.sau.com.au/forums/topic/475561-intro/
Welcome. 260RS is one of my favourites. But i have odd tastes (R33s for example).
You've come to the right place for help. Everyone has an opinion here. [emoji23]
Would love to see pictures of your car. [emoji7]
https://www.sau.com.au/forums/topic/475561-intro/#findComment-7893219
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
