have gone the manual conversion route, leaving a few auto-related items for sale.
First is a valve-body upgrade for the RE4R01A transmission. This is all fully assembled so just needs to be bolted onto your transmission and good to go. The upgrade is based off a Transgo kit that has then been further tuned by KEAS; the shifts are wayyy improved from stock without being too clunky/jerky, just a nice quick shift that holds power with no flaring.
It's still in the transmission to keep everything nice n clean for the moment but hey, here's a pic of the complete transmission, just cos.... $200 for the valve body, and can post anywhere in Aus.
The transmission itself; I believe one of the planet gears is slightly fkt, but still runs and changes gears excellently-like - just it develops vibration in 3rd gear around 90kph, which goes away when changed into O/D. The trans would be fine for a rebuild or for parts. $50, or will give away with the valve body for anyone local picking up the aforementioned item.
Furthermore; I have a B&M auto-transmission cooler (still on vehicle, to be removed shortly). This comes with mounting brackets and custom hard lines that will all bolt in place with no mods, on an R33 gtst in the driver's side behind-front-bumper-vent-area. Ditching the stock cooler that is mounted in front of the radiator massively decreased my engine coolant temps, in addition to the trans fluid being much more effectively cooled by the B&M cooler. The B&M cooler is also very robust, pretty sure you could whack it with a golf club and it would laugh it off (no I haven't tried it) so small stones etc from the road won't hurt it. Will be pulling it off this weekend and will post pics then. Looking for $150, once again can post aus-wide.
https://www.sau.com.au/forums/topic/475588-r33-auto-related-performance-items/
  • 1 year later...
    • There are certain tasks, like replacing head gaskets, where it is very much best to already know what you are doing, and if you are not already an expert, then the next best thing is to have an expert around to help it get done. Little annoying checks and steps that are easy to forget or not interpret the results of properly, etc etc. It is hard to convey that to someone as a lesson prior to taking on a job, because there can be a whole list of "if you see this then it means that", or "if this is what you find then you will need to do these other 4 steps first". All the little bits of knowledge around sealant choice (ie, sealant at all? or no sealant? sealant only in certain parts of the gasket? sealant for this type of gasket but not that type of gasket? etc etc) cleanliness checks and methods, surface straightness and finish checks and methods, etc etc, all combine to mean that people who have done many of the same type of job will struggle less to get a good result than someone who hasn't done it before. I've been around this stuff since forever. But I will still consult with my expert(s) before taking on the big stuff with higher risk profile.
    • Well if I end up having to do the head gasket I will certainly find the necessary tools and instructions before beginning... Let's hope it won't come around.   Definitely. Depends on the job but I think "if you want it done right, do it yourself" applies almost every time
    • Can you at least move to a location without so many ladders, black cats and mirrors precariously propped up ready to be knocked down? Or buy yourself a 1 ton bulker bag of salt to drag around with you. Just, you know, sling it over your shoulder?
    • Meh, what's the worst that can happen? If is is supposed to have a washer, and: the spring retainer seals reasonably well on the surface, maybe just allowing a little bleed of oil out, and the spring does not coil bind when compressed that little extra bit, then the end result will be slightly higher relief pressure setpoint, and no other noticeable effects.
    • Weirdly I see a flat washer on aftermarket pumps but as you said it doesn't seem like new OEM pumps have it. EPC doesn't break out the regulator as a separate component either. I'm guessing if the pump came that way it's safe to use as-is.
