Hi , first time post here. I have a 2.0L 8 valve SOHC motor (pinto) on E85 with 630cc injectors GT2860RS 0.86 turbo External WG (flapper welded shut) Haltech ps1000 making 301whp at 5800rpm 20psi. Power bug has bitten and I'm chasing another 40whp to hopefully crack into 11sec 1/4 mile. Because my hotside is custom it will be costly to change to T3 manifold and Vband dump etc so I've looked at the GTX gen2. It's rated at 475 crank hp, 115hp higher than the GT version. The only difference between the two is the billet compressor wheel and cover and the shaft speeds on compressor map are 35,000rpm higher.  Is it foolish to think this could make 340whp? I'm trying to decide on this or GT30 , if the GTX2860R GEN2 can do it I'll stick with it. If anyone can vouch for this turbo making those numbers please chime in . Thanks
Edited by Boosted Esky
https://www.sau.com.au/forums/topic/475593-340whp-gtx2860r-genii/
I'm not familiar with the engine or what it can flow/handle, but the GTX gen1 or gen2 is a significant step up from the GT series. Much bigger/better compressor map suited for higher boost. If your setup can handle 20psi of a gtx28 turbine, I think you'll see a noticeable improvement.
The compressor housing is quite a step up compared to the GT in size, but looks like you've got the space for it
I went from GT2871 to GTX2867 gen1 years ago and very happy with the results.
2 hours ago, Boosted Esky said:
The engine is fairly well built. ARP bolts throughout, Cosworth YB steel rods and YB pistons. Cometic MLS head gasket. Sounds like I should wind it up :)
Would be an interesting little package.  No desire to go with  a complete YB engine for cylinder head flow efficiency? 2 valve Pinto head would be a sticking point in chasing hp if you got really serious.
By sticking with existing manifolding / turbine / wastegate you're definitely making life easier with the change over.
Boost would be the preferred way to more hp than revving the engine harder IMO so the thinking is fairly sound if you're wanting a 40-50hp increase.
Be interested to see the before/after results of this upgrade.
Hi Dale. A YB cosworth head would be ultimate but would've added about 7 to 8K to my build cost. In standard form the YB head doesn't flow that great so porting, bigger valves, better cams etc. The factory brake booster would have to be deleted and bias pedal box installed with remote reserviors etc.  The aluminum YB heads are also known for going  soft and cost about 3k to harden if a suss one was purchased. The going rate for a standard used YB head in GC is about 3k. I was also keen for a challenge to do something different and it's been a whole lot of fun since having it on the road. PB at the drags is 12.7 114mph so hopefully can get a high 11 with another 40hp. Thanks
  • 1 year later...
With a second Bosch 044 installed the GTX2860R genII made 355whp at 26psi.  Car ran 11.7@ 121MPH a month ago :)
  • Like 4
On 12/09/2020 at 9:25 AM, Roy said:
LOLs, its making the same as my T38 on the YB in my Cossie...i  really need a new hair dryer for the old girl.  Your setup is  bang on what I want to piece together in a MK 1 Cortina. Looks a m int intall. Did you do the abrication?
Yes turbos have come a long way since the old tech T3's and T4's. I was in disbelief at the dyno seeing the result. Super happy with it.  Thanks very much.. here's a more recent pic :) The turbo manifold & dump pipe were made by Dan @ Go Pipes and the aluminium intercooler pipes, turbo inlet & BOV return pipes by Silke Fabrications.
  • Like 4
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
