You’re right, the turbo did sound whistley  on the drive up to the mapper and doesn’t sound half as bad now.
The turbo did over come the leak but at the cost of working harder. Surely it would have build boost differently to if the gasket wasn’t leaking? That’s the best thing about analogue gauges as you can observe fluctuations and trends, digital doesn’t really let you see that unless you are logging...
  • 1 month later...
So I got a pal of mine who’s mapped a few Emanage ultimates to plug his lap top into the Emanage to see if there was anything untoward or just to look at the map (it’s just numbers to me) .
I was a bit out off at the shock he was in as he said that it was retarded across the entire rev range, also, the afm was selected as a standard afm and not as a z32 one which I have, the injectors were also standard when they should have been selected as 440cc.
We took it out with his wide band stuffed up the exhaust ?
He said it was really rich, we got back to mine and he tested the lambda sensor, it was “flatlined” so that needs replacing.
The only thing that I can confirm is that the brown plug behind the drivers headlight does not lock the timing at 15 degrees when it’s unplugged but does lock the auto box in third as I asked him to measure it. So that is good for mapping on the dyno I guess.
So, I’m going to get a new sensor and ask him to have a crack at mapping it. Or at least ask him to take another look.
Will report back... ?
Just for reference its this brown plug ?
  • 1 month later...
Quick update..
So the car go’s to a show this weekend and I know driving without a decent map could be engine suicide but I’ve had the fuel curve looked at and have been assured that’s it’s safe and there’s so much timing pulled out of it that it won’t det so I’ll trundle down to the show.
Took it out this saterday just gone to make sure everything is just so and ended up forgetting that it shouldn’t be thrashed until it’s been looked at properly and gave it the full biscuit... to my surprise it took off like hell in the night, it felt like it did previously, like before I lost the 58hp the only thing I’ve done recently is stop the re circ from the cam covers to the intake and blank off the lines from the plenum to carbon canister (now gone). I’m not complaining but I’d like to know what the hell is going on still, maybe the maf needs a clean? It is third hand so I may try that.... I’m getting it totally looked at early next month, the entire shooting match mechanically and ECU side by somebody that is very familiar with the emu and can spanner as well....
Will report back...
Edited by paulzy123
Spelling
  • 1 month later...
Hi,
The problem is fixed, I took it to a mate of mine that mapped his own car on the Emanage ultimate. He spent a good long time looking at the wiring. The injector earth wire had a dry joint in the pin in the loom connector and eventually snapped when we went to road map it so that got a new soldered lug. The lambda sensor was goosed so that got replaced. The SAFC 2 I was using to monitor knock still had a map on it and was wired in series with the Emanage wiring which was causing issues so the AFM side of it got removed, the AFM (z32) was spiking at 3.8 volts then dropping to 2.8volts straight after which was also causing problems so he “clamped the voltage?” Apparently it’s not to be used as a permanent fix it’s till I buy another AFM. We spent a couple of hours driving around and doing pulls while he sat on an ancient laptop typing and clicking away saying, “try that” and “do that again” until he turned to me and said right let’s turn the boost up.
At 18 psi it felt immense and it really was quick enough but he said I could go more so I did but in the end I settled at 19psi as upping it more didn’t seem to feel any quicker. All in all I was on the road around four hours and in his garage at least a day ?
Its quite quick now, well for an auto.
Well, that concludes my thread, thanks for all your advice and help ?
Cheers
Paul
  • Like 4
All's well that ends well. One lesson to be learned is that its very hard to guarantee  a good tune. The tuner might be over -rated, or a shop with a good reputation may hand the job to an employee who is not up to par (although one would like to think that such a person would have their work checked). One thing is for sure a good tune takes time and money!
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
