Hi fellas, I recently got a tune for my R33 and noticed that the Turbosmart manual boost tee has been locked. The knob to increase the boost is locked tight. Not sure if it's broken or a lock feature has been activated? I got the older model.
Does anyone know how to unlock it?
Thanks in advance.
Image result for turbosmart manual tee
https://www.sau.com.au/forums/topic/475608-turbosmart-manual-boost-tee-locked/
I believe there's a grub screw you can loosen up.
Anyhow, invest in a decent EBC. Bleed valves aren't exactly precision instruments.
Also shameless plug time, I also have a Blitz DSBC Dual Solenoid EBC for sale lol.
  • Like 3
Thanks mate. I'm going to buy an EBC soon but for now, will run with this.
How do I loosen the grub screw with what tools?
An allen key? lol
  • Like 1
  • Haha 2
Given that u didn’t know what tool to use I would guess u don’t really know what to do so I would be leaving it alone.
Also if u got a tune why are u trying to adjust the boost now?
  • Like 1
Thanks guys.
I might leave it alone. The tuners blocked it off and I was cleaning up my engine bay a bit and noticed that the boost solenoid was blocked/locked. Will be upgrading to a EBC soon though.
  • Like 1
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
    • I have information on this for anyone that comes looking again. https://www.facebook.com/share/p/18gsbFaYTU/ The rb25det neo from the stagea has the same sumo as rb26 and r32 gts4 (and other awd models). The sump that has caused so many problems during swaps are from the awd neo Gloria's. The casting numbers on the block and oil pans are different so this may help identify if you can't confirm where the motor came from
    • Not feasible to fix the boot lid you had? Damage looked minor/hard to even see :p Source: Drove into something recently and you should be happy you didn't!
    • Another new used boot arrived at the painters, it was sent back as there was nearly as much damage as the original one I want to replace  Finding a clean used boot lid is proving problematic, and I'm not keen on dropping $1500 on a new one from Mazda Sigh....
