Hi fellas, I recently got a tune for my R33 and noticed that the Turbosmart manual boost tee has been locked. The knob to increase the boost is locked tight. Not sure if it's broken or a lock feature has been activated? I got the older model.
Does anyone know how to unlock it?
Thanks in advance.
Image result for turbosmart manual tee
https://www.sau.com.au/forums/topic/475608-turbosmart-manual-boost-tee-locked/
I believe there's a grub screw you can loosen up.
Anyhow, invest in a decent EBC. Bleed valves aren't exactly precision instruments.
Also shameless plug time, I also have a Blitz DSBC Dual Solenoid EBC for sale lol.
  • Like 3
Thanks mate. I'm going to buy an EBC soon but for now, will run with this.
How do I loosen the grub screw with what tools?
An allen key? lol
  • Like 1
  • Haha 2
Given that u didn’t know what tool to use I would guess u don’t really know what to do so I would be leaving it alone.
Also if u got a tune why are u trying to adjust the boost now?
  • Like 1
Thanks guys.
I might leave it alone. The tuners blocked it off and I was cleaning up my engine bay a bit and noticed that the boost solenoid was blocked/locked. Will be upgrading to a EBC soon though.
  • Like 1
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
