Hey there new to the forums, found heaps of useful info on here and I'll probably need quite a bit of help too with things I can't find on here sooo bit about myself;
I'm located in New Zealand and I currently own 2 r33 skylines
Have a bit of a diy sorta nature and am generally pretty good when it comes to wiring things up
1st one is the black one and I'm the second owner so everything done to it is of a professional standard and it's my daily
Specs;
Rb25de factory manual
Vlsd diff (also factory)
Big brakes (factory)
5 star alarm
Custom exhaust (certed)
18inch moteji rims
Lowered with cobras in the back and tein? (Green) in the front
S1 tail lights (smoked out)
yada yada yada
Second one is a project for the missus
Specs are
Rb20e auto
Series 2
Push to start button with RFID tags as security and keyless entry (no ignition barrel)
... She's a work in progress
I'll attach a couple photos below, consider myself introduced (:IMG_20181209_193416.jpegIMG_20181124_175423_449.jpegFB_IMG_1542348682888.jpegIMG_20181108_184735.jpeg
https://www.sau.com.au/forums/topic/475614-no0b13/
Specs;
5 star alarm
18inch moteji rims
yada yada yada
Specs are
Rb20e auto
Series 2
I'll attach a couple photos below, consider myself introduced ?IMG_20181209_193416.jpegIMG_20181124_175423_449.jpegFB_IMG_1542348682888.jpegIMG_20181108_184735.jpeg
Welcome to SAU mate. Good to see a 4-door R33 as they're quite rare in Aus let alone two.
Any further mods planned for either one or leaving them stock?
https://www.sau.com.au/forums/topic/475614-no0b13/#findComment-7893827
Cheers mate (:
Leaving the black one close to stock maybe adjustables and different rims but that'll do for a daily
The silver one is currently a wide open project so I'm in the process of fixing a small problem and making it completely keyless with the use of rfid tags as security, on the hunt for a decent set of rims and also ordering some cop lights and sirens for it, maybe a couple gauges , then when the time comes either flick it or 25det convert it (:
https://www.sau.com.au/forums/topic/475614-no0b13/#findComment-7893914
1 hour ago, Tailz94 said:
Cheers mate ?
The silver one is currently a wide open project so I'm in the process of fixing a small problem and making it completely keyless with the use of rfid tags as security, on the hunt for a decent set of rims and also ordering some cop lights and sirens for it, maybe a couple gauges , then when the time comes either flick it or 25det convert it ?
Sounds awesome mate!
The silver one sounds like it’s going to be a very interesting project especially with the cop sirens! You should start a build thread.
https://www.sau.com.au/forums/topic/475614-no0b13/#findComment-7893926
cheers yeah I'll probably start one tomorrow when I get the time, was nothing short of a wreck when I got it , was actually too embarrassed to take photos [emoji1787]
https://www.sau.com.au/forums/topic/475614-no0b13/#findComment-7893927
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
