  • 2 months later...
  • 4 months later...
  • 4 months later...
really nice clean build! im currently in the process of doing the same thing what a time consumer getting under the car that clean, hats off to you. arc air box is sick. good work m8
where are you running your breather hose on the pvc side,  as I can see its not running to the pvc looks blocked off. just curious if to sump, open atmosphere, or hidden catch can.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
