After 4 years at about 350kw I went in to my tuner after I installed my new intercooler to get a checkup.
All 6 cylinders had awesome compression and the dyno still showed 354kw atw (lower conversion method used as well).
Looking at the shops workers car with the same head setup and turbos using E30 he was getting 437KW...a big jump in response.
It convinced me this E thing is worth the investment - now to order some Speedflow 200 series lines.  How long are the stock lines in an R32 I cant find anything about that.  I know the car is 4500mm.
So I was going to get 13m should be enough for 2 feed lines and 1 return.  Surely someone has noted it before :)
Thanks.
https://www.sau.com.au/forums/topic/475648-r32-gtr-fuel-line-length/
You don't need twin feeds.
Distance isn't even 4.5m as the tank isn't at the back of the car and the rail isn't at the front.
best way to do it is to modify and use the Hicas lines as they're right there, or you can do what i did and be dodgy and run the -6 lines in the old brackets for that, they fit right in and tuck up really well actually.
I think i used 9m of hose and i also got a water feed for the turbo and a power steering line out of it.
Depends what you want to do.
I have a 8an feed and return. I don't think twin feed is necessary. I bought 2 4.5m lengths as that's what aeroflow had. I had some left over, as sneaky Pete said you end up using it for other things.
Better to have more than not enough. It's never gonna be exact.
Proper way to do it would be to run hard lines TBH, less risk with debris strikes from under the car.
Though as said I was lazy and it turned out pretty damn good so i wasn't too worried.
Given the guy with the same turbos is only making 437kw i'd say -8's not needed in this case.
people have made 400kw on stock lines with E85 and -6 is something like 50% bigger compared to that
Agree. Hardline would be better. Would be a pain in the ass to do on the floor in the garage neatly.
I ran mine the same as yours basically. 6an ID isn't much bigger than the stock lines. 8an ID is about 10.5mm inside.
If you're doing it, better to go bigger. The difference in cost of hose and fittings is negligible. Get ready to spend a few thousand.
You will need a rail, fpr, different fuel filter/s, possibly surge tank with multiple pumps.
Will give you plenty of head room. Sort of wish I went 10an but 8an will be good for 1000hp or so I think.
At least you wont have to touch the fuel setup again because if you upgrade it's pretty much bin everything.
  • Like 1
Yeh plan is to get a Frenchys performance Garage In Tank surge tank with 2 E85 pumps.  This means I do not get any compliance issues having a surge tank and no smells.
ID 1350x injectors
Link G4+ with ethonal content sensor (already purchased) so good bye HKS F-Con you have done me well.
Fuel lines 2 feed 1 return so I am future proofed and dont have to worry about fuel lines been old or ever again haha.
Edited by Stixbnr32
That kit only has a single fitting for feed. Y pipe is in the tank.
If, for some reason, you must have a twin feed rail (see topic on that from a few days ago also) run a -8 feed and Y pipe it into -6 in the bay.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
