Hi folks, I would like to get some inputs on this issue with my R32 GTR...
Car was on the dyno, the fuel pressure would rise to ~60psi no problem, stayed at ~60psi for about half a second then dropped to ~50psi, and then stayed at ~50psi until let go of throttle.  Idle fuel pressure stable at 43psi.
Made 315kw previously on 93 octane, now 275kw...  Injector duty cycle at 108%, but AFR stable at ~11.
A quick run down of parts: Nismo fuel pump, R35 injectors, R35 AFM, NZEFI resistor delete, brand new OEM FPR, Nistune, Garrett -9s.
Is the Nismo pump running out...?  Or could it be the pesky fuel pump control module...?  What does the FPCM do anyway?
Edited by TXSquirrel
My Nismo pump was purchased new from RHDJapan 3 years ago.  Sounds like the consensus is that the Nismo pump is much more likely the culprit than the FPCM? Is there any way to test the FPCM?
So if I'm to bypass the FPCM for direct feed, what gauge wire is recommended?
And what's that little valve inside the tank for? I always wonder why it's there...
FPCM is most likely exacerbating the issue, also that valve. Nissan put those OEM valves in to bleed once it exceeds a particular pressure.
I beleive it was mainly a safety feature in the even of clogged fuel filters, etc. however a big pain the arse when you start applying boost.
I would just simply delete the pressure relief valve and ground off the fuel pump to the body, i.e. bypassing the FPCM.
  • Like 1
  • 1 month later...
I finally got around to diagnose this issue in detail, and I am not sure what to make of what I discover.
The FPCM is working fine, doing its thing by increasing voltage as engine load increases.  The problem is with 12v source for the pump.  I first measured the voltage at pump relay, and I was only getting 10.5v ignition on and 11.7v at idle, about 2v below battery voltage.  Then I measured at the fuse, same issue.  I tried the fuses next to pump, which are various lights, no problem at all, 12.5v with engine off and close to 14v with engine on.
So what happened between power source and the fuse harness?  How was it wired, straight off battery?  Look at the electrical diagram it's not too clear to me.  Looks like the EGT sensor is tee'd off the same source...?
Not surprising at all, 30 year old car means 30 year old wiring, and nissans wiring was nothing great to begin with. You are just getting a voltage drop over the fuel pump power feed wire.
I will quote myself here because that was and still is the correct thing to do.
On 12/20/2018 at 7:23 AM, iruvyouskyrine said:
Bypass FPCM using a relay and direct power feed, and put a new fuel pump of your choice (walbro 460 my recommendation) and go from there.
Bypass the FPCM, useless thing to begin with. A drop resistor with new pumps is only going to reduce it's life.
You want to control pumps via PWM, if not just wire it direct to a relay.
I'm assuming you're American, stubborn and like to do things the hard way. I recall all of us telling you to go with modern larger injectors before too.
When my tuner first noted the fuel pressure issue, he already suggested bypassing the FPCM or installing an Aeromotive fuel pump controller.  He did that for all the cars with aftermarket pump.  I am just trying to keep my car as close to factory and use Nissan parts whenever I can, so it's just me with my way.  That's why I'm running R35 injectors, which are still more than what the -9s can put out anyway.
After looking at the diagram more, I'm guessing this 12v source actually runs through the ignition switch.  So if I can get a confirmation that will be great.  Nissan did that with headlight harness, not a real surprise if 30 years ago Nissan decided to run fuel pump 12v through ignition switch.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
