Hi, having a garage clean out. Need them gone. Negotiable. imageproxy.php?img=&key=4b1e78680f916b86imageproxy.php?img=&key=4b1e78680f916b86Located south east Melbourne.
240k L24 inlet and exhaust manifold $100
L20A injected inlet manifold and fuel rail $250
260z flat top twin SU carburetor $250
Round top twin SU carburetor $400
L series 5 speed gearbox $400
Dr30 hubs and rotor $100
DR30 LHS guard $200
MR30 struts, springs, hubs, rotor, calipers $350
Mr30 tail lights $50
R32 centre console $100
R32 centre control surround (has a crack) $50
R32 rear bumper $150
R32 rear pods $100
R32 aircon condenser $150imageproxy.php?img=&key=4b1e78680f916b86imageproxy.php?img=&key=4b1e78680f916b86
CA18 starter motor $50
S13 rear tein coilovers $250
Edited by luwayy
https://www.sau.com.au/forums/topic/475657-240k-c210-r30-r32-and-random-bits/
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
