Hi guys. not sure is I should post this here but seems no better places for this topic...
So I am moving to Tas next month from Vic with my R33 registered in Vic. After a quick research I found that I have to pass AIS inspection to get Tas rego&plate.
So can anyone here explain a bit about AIS inspection? Is it similar to Vic's rwc test? How hard&strict is it ?
My modifications includes freddy plenum,fmic, bov, ebc, coilovers and something not so obvious.
Any other suggestions ?
Thank you all in advance.
Edited by Michael33
https://www.sau.com.au/forums/topic/475671-moving-to-tas-from-vic/
Will you be visiting Victoria regularly by any chance?
"Yes officer, I've moved to Tasmania but I catch the ferry back to Victoria every month or so to visit family and for work."
And leave it registered in Vic.
No.  I need to transfer the registration to Tas. Maybe even a Tas license.
Dont want to abandon my 33 at all. Sad.
My dad lives in NSW and his car is registered in Vic.  Has been for 10 years.  Heck we had a car registered in QLD that we drove in Vic for 15 years without issue as well.  You don't really need to change the rego.  No one will give  a shit.
Okay.
I am gonna keep my vic plate.
Thanks bro.
  • 3 weeks later...
On 12/23/2018 at 12:57 AM, Michael33 said:
Okay.
Thanks bro.
If you ever get pulled over and the copper questions it, just say you ferry back to Vic regularly to see family.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
