This is my first r32 gt-r. I bought it with what seems to be a dead cylinder #6. Will be doing a compression test soon. My question is this, can you access the #6 piston from the bottom if I remove oil pan? I know I'd also have to remove the head to remove the piston from the top. I was thinking of flex honing the cylinder and installing new rings.
https://www.sau.com.au/forums/topic/475675-ring-replacement/
If there was a simple solution surely the seller would already have done it. Have you even jacked up the car to consider what it would take to remove the sump/diff!? Do the compression test. If you have access stick a camera down the plug hole.
Hope the price took into account the problem mate.
If you want to replace the rings you need to at least hone the cylinder.
To hone the cylinder you need the piston and rod out.
To take the piston and rod out you need the head off, or may be the crank out
To take the crank out you need to undo the rear main oil seal and oil pump bolts, and remove the sump
To remove the rear main oil seal you need to remove the gearbox. And clutch. And flywheel.
To remove the oil pump you need to remove the timing belt gear. And timing belt. And timing belt cover. And the radiator.
To remove the sump....well....don't know. Probably front subframe out which means brakes off, steering shaft disconnected, ABS unplugged, top shock bolts and upper control arm bolt, power steering lines off, exhaust dump pipe off.
We could do this list all day. Basically you have a repair that is going to cost a minimum 5 grand to do at a shop if they do minimal work. If at all possible you should spend about twice and rebuild the whole motor including new seals and gaskets, rings, bearings, machining, oil and water pump, head reco. You should consider boring out the block and putting in forged pistons at the same time.
You have one of the best performance cars ever made, it would be a shame to have an engine that is not right.
  • Like 3
Well, actually, you can get a rod&piston out with the crank still in.  But getting the sump off a GTR in car is not a pleasant exercise.  Pleasantness issues aside, the pure silliness of attempting to hone just one cylinder in an RB26 in situ rather than doing the job properly still needs to be stressed.  Either do it properly or sell it on to someone who will.
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
