This is my first r32 gt-r. I bought it with what seems to be a dead cylinder #6. Will be doing a compression test soon. My question is this, can you access the #6 piston from the bottom if I remove oil pan? I know I'd also have to remove the head to remove the piston from the top. I was thinking of flex honing the cylinder and installing new rings.
https://www.sau.com.au/forums/topic/475675-ring-replacement/
If there was a simple solution surely the seller would already have done it. Have you even jacked up the car to consider what it would take to remove the sump/diff!? Do the compression test. If you have access stick a camera down the plug hole.
Hope the price took into account the problem mate.
If you want to replace the rings you need to at least hone the cylinder.
To hone the cylinder you need the piston and rod out.
To take the piston and rod out you need the head off, or may be the crank out
To take the crank out you need to undo the rear main oil seal and oil pump bolts, and remove the sump
To remove the rear main oil seal you need to remove the gearbox. And clutch. And flywheel.
To remove the oil pump you need to remove the timing belt gear. And timing belt. And timing belt cover. And the radiator.
To remove the sump....well....don't know. Probably front subframe out which means brakes off, steering shaft disconnected, ABS unplugged, top shock bolts and upper control arm bolt, power steering lines off, exhaust dump pipe off.
We could do this list all day. Basically you have a repair that is going to cost a minimum 5 grand to do at a shop if they do minimal work. If at all possible you should spend about twice and rebuild the whole motor including new seals and gaskets, rings, bearings, machining, oil and water pump, head reco. You should consider boring out the block and putting in forged pistons at the same time.
You have one of the best performance cars ever made, it would be a shame to have an engine that is not right.
  • Like 3
Well, actually, you can get a rod&piston out with the crank still in.  But getting the sump off a GTR in car is not a pleasant exercise.  Pleasantness issues aside, the pure silliness of attempting to hone just one cylinder in an RB26 in situ rather than doing the job properly still needs to be stressed.  Either do it properly or sell it on to someone who will.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
