Dyzzii Posted December 30, 2018 Share Posted December 30, 2018 Hi guys I've been lead to believe by my tuner that my VVT cam gear is making some noise. Around 5000rpm every single pull a noise is picked up by the knock sensor, which keeps going until about 5500rpm at which point it stops, and the ECU sometimes thinks it's knock and pulls timing to compensate. Tuner seems to think it is my intake cam gear, and believes it may be getting a bit noisy for some strange reason. Noise has been described to me almost as a "ddddrrrrrrdrrrrrdrrrrdrrrrrrrrdrrrrrrrr" (best way I can describe it on here) and happens every single pull. Can only be heard through the knock sensor which makes diagnosing it a real pain, as putting it on the dyno every time I replace a component is not even remotely practical. Normally this would not bother me enough to pursue, but because it is affecting how the car drives on some pulls, it's not something i'm happy to leave alone. He has also suggested that it could potentially be a lifter, but that seems very unlikely as these cars have solid lifters off memory. So I contacted Nissan, and am unable to get a brand new intake cam gear for less than $1,200 which is absolutely absurd. So i'm now contemplating other solutions to my problem, and have been thinking I would actually be better off going aftermarket cams with adjustable cam gears. However my setup is still relatively stock with a few bolt ons (front mount, exhaust, cold air intake, nistune ecu, stock turbo, stock injectors etc). So my questions really are: 1. Are there any other suggestions for what this noise could be? 2. What other solutions would I have rather than paying $1,200 for a gear from Nissan? 3. Would going cams on a setup as stock as this even be worth it? 4. How much power would I lose if I just went adjustable cam gears on the stock cams? On a side note, I have recently replaced the cambelt with a GATES timing kit as I was lead to believe that could have been the culprit. Mechanic told me the previous cambelt had not been done very well, and had likely been overtensioned. So this rules out the cambelt or any related tensioners to it, but could reinforce the idea of the cam gear being the culprit?... Appreciate any and all feedback! Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/ Share on other sites More sharing options...
Rusty Nuts Posted December 30, 2018 Share Posted December 30, 2018 What other solutions would I have rather than paying $1,200 for a gear from Nissan? part No. 132025-5L301 should be what you need. Available from AMAYAMA approx $854 14 days delivery but run your vin number to be sure. Mechanic told me the previous cambelt had not been done very well, and had likely been overtensioned. So this rules out the cambelt or any related tensioners to it, but could reinforce the idea of the cam gear being the culprit?... This statement set the bullshit meter to high. The camshaft sprocket rotates on a substantial journal which is how the VCT moves it. It is more likely the VCT internals are making the noise...they are not rebuildable Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7894990 Share on other sites More sharing options...
Rusty Nuts Posted December 30, 2018 Share Posted December 30, 2018 Have you tried replacing the front knock sensor they rarely go wrong but shit happens. 1 Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7894992 Share on other sites More sharing options...
AngryRB Posted December 30, 2018 Share Posted December 30, 2018 Strange the noise is only at 5k, when mine needed replaced it was rattling loud at cold start idle speed.. I got mine thru kudos motorsport around the $850 if I remember correctly. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7894999 Share on other sites More sharing options...
Dyzzii Posted December 31, 2018 Author Share Posted December 31, 2018 11 hours ago, Rusty Nuts said: Have you tried replacing the front knock sensor they rarely go wrong but shit happens. Appreciate the replies I will look into the part! And no I havent replaced the knock sensor. It appears to be working as intended so have had no reason to replace it. My main concern is that is a massive amount of cash to fork out to only “potentially” fix an issue. But I may just have to bite the bullet. 1 hour ago, AngryRB said: Strange the noise is only at 5k, when mine needed replaced it was rattling loud at cold start idle speed.. I got mine thru kudos motorsport around the $850 if I remember correctly. No audible noise whatsoever at idle or outside the car. Listening to it pulling on the dyno you’d never know and the power/torque curves are fine which makes it even stranger. I’m worried at the fact he thinks it “might be” the culrpit. So difficult to diagnose as every time i replace something it would have to be chucked back on there to listen for the issue again. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895003 Share on other sites More sharing options...
Rusty Nuts Posted December 31, 2018 Share Posted December 31, 2018 I agree with Angry RB the noise from mine was generated at idle only, But I had a spare engine and swapped over VCT. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895007 Share on other sites More sharing options...
Rusty Nuts Posted December 31, 2018 Share Posted December 31, 2018 Once came across a Neo that had a lifter bucket that would "cock" slightly in the bore and jam a few thou low which caused the lobe to slap hard against the shim. Changed the shim and it stopped doing it. The old shim had a substantial mark on it. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895008 Share on other sites More sharing options...
Rusty Nuts Posted December 31, 2018 Share Posted December 31, 2018 Mate, don't discard the faulty knock sensor suggestion. Search this site for Faulty Knock sensor there are eight pages of issues experienced , some very similar to what you are experiencing 1 Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895011 Share on other sites More sharing options...
Dyzzii Posted December 31, 2018 Author Share Posted December 31, 2018 12 minutes ago, Rusty Nuts said: Mate, don't discard the faulty knock sensor suggestion. Search this site for Faulty Knock sensor there are eight pages of issues experienced , some very similar to what you are experiencing You think the knock sensor could potentially just be having a meltdown and pinging which is what he is hearing? That would make life a hell of a lot easier. 1 hour ago, Rusty Nuts said: Once came across a Neo that had a lifter bucket that would "cock" slightly in the bore and jam a few thou low which caused the lobe to slap hard against the shim. Changed the shim and it stopped doing it. The old shim had a substantial mark on it. This has completely lost me here haha, i know a fair bit about the workings of motors but am lost as to what you’re talking about here haha. Any more idiot-proof way of putting it? so you’re thinking is it’s more likely to be something else rather than the cam gear, as most past experiences had an audible noise at idle? Thanks heaps for your help so far too. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895013 Share on other sites More sharing options...
Dyzzii Posted December 31, 2018 Author Share Posted December 31, 2018 Oh wow have had a read of the knock sensor threads. Only thing is my tuner can hear it when listening in through headphones to the sensor? Or would the sensor potentially be magnifying the feedback that was just normal engine vibration and that’s what he’s hearing? i’d think he’d have suggested this to me though? He has a hell of a lot of experience with skylines and is a very respected tuner in NZ. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895014 Share on other sites More sharing options...
Rusty Nuts Posted December 31, 2018 Share Posted December 31, 2018 The knock sensor is tuned to detect the engine knock/detonation frequency, when they shit themselves they detect other frequencies as knock. Your tuner is hearing noise which is possibly fooling the sensor (and him?) Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895020 Share on other sites More sharing options...
Ben C34 Posted December 31, 2018 Share Posted December 31, 2018 1 hour ago, Rusty Nuts said: The knock sensor is tuned to detect the engine knock/detonation frequency, when they shit themselves they detect other frequencies as knock. Your tuner is hearing noise which is possibly fooling the sensor (and him?) That's assuming he is listening to the factory sensor. Ask if he used it or his own sensor when tuning to rule out this possibility. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895025 Share on other sites More sharing options...
Rusty Nuts Posted December 31, 2018 Share Posted December 31, 2018 I'm assuming nothing of the sort, regardless how the tuner is listening its the output of the factory knock sensor that is signalling the ecu to pull timing Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895028 Share on other sites More sharing options...
Dyzzii Posted January 1, 2019 Author Share Posted January 1, 2019 21 hours ago, Ben C34 said: That's assuming he is listening to the factory sensor. Ask if he used it or his own sensor when tuning to rule out this possibility. I believe he is using the factory sensor. Do you guys happen to know what sensors are compatible for the 25det neo? Can i just get any neo knock sensor as a replacement? Or must it be 25det? Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895062 Share on other sites More sharing options...
Dyzzii Posted January 1, 2019 Author Share Posted January 1, 2019 19 hours ago, Rusty Nuts said: I'm assuming nothing of the sort, regardless how the tuner is listening its the output of the factory knock sensor that is signalling the ecu to pull timing Yeah that makes sense. Just weird to not have any CEL's or anything like that, but from what those other threads said it doesn't appear that they throw codes. Am I right in saying there are 2 knock sensors on the car? And if so, would you recommend replacing both of them, or just the one he is listening in on? May have to look around some wreckers for one and fingers crossed it helps! Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895063 Share on other sites More sharing options...
Rusty Nuts Posted January 1, 2019 Share Posted January 1, 2019 Yep, there are two, the most common ones used are Part No. 2206059S00 they are used on multiple Nissan engines RB's and VG's. New between $160 and $180 but grab a couple from the wreckers, take one of yours as a sample. I'm running RB30 ones in my 25/30 and ecu is happy. There's a pair for sale on ebay for $14 the guy is in Bundaberg gotta be worth two schooners. 1 Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895065 Share on other sites More sharing options...
Dyzzii Posted January 1, 2019 Author Share Posted January 1, 2019 3 hours ago, Rusty Nuts said: Yep, there are two, the most common ones used are Part No. 2206059S00 they are used on multiple Nissan engines RB's and VG's. New between $160 and $180 but grab a couple from the wreckers, take one of yours as a sample. I'm running RB30 ones in my 25/30 and ecu is happy. There's a pair for sale on ebay for $14 the guy is in Bundaberg gotta be worth two schooners. Bugger i’m from New Zealand . I’l have to scout a few wreckers out online from here and hope to come across some. Am tempted to just go brand new to eliminate the issue but I guess that’s pointless as I still don’t definitively know what the issue is! Thankyou heaps for your help so far. Will likely have sorted some by the end of the week. Only issue is i’l have no idea if they’l fix the problem until its back on the dyno Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895077 Share on other sites More sharing options...
Rusty Nuts Posted January 1, 2019 Share Posted January 1, 2019 (edited) Why not a nice bit of straight road surely you could feel the timing being pulled.also( Maybe the guy on ebay posts to NZ) Edited January 1, 2019 by Rusty Nuts Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895078 Share on other sites More sharing options...
Dyzzii Posted January 2, 2019 Author Share Posted January 2, 2019 17 hours ago, Rusty Nuts said: Why not a nice bit of straight road surely you could feel the timing being pulled.also( Maybe the guy on ebay posts to NZ) I’ve never actually felt the timing pull noticably. To me it feels smooth and constant. I don’t believe it pulls timing every time, just occasionally. Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895127 Share on other sites More sharing options...
Rusty Nuts Posted January 2, 2019 Share Posted January 2, 2019 Fair enough, wish you the best of luck with it mate and hope its a cheap fix. 1 Link to comment https://www.sau.com.au/forums/topic/475719-rb25det-neo-cam-gears/#findComment-7895128 Share on other sites More sharing options...
