Welcome. Welcome one welcome all - to partz for sells. Can post auswide, pm for costs.
First - Nismo adjustable fuel pressure regulator. Fairly new, and in good working order. I know this for fact, cos i'm still currently using it, but won't fit my new fuel rail so...
$100.
GK Tech poly subframe bushes. These are BRAND NEW - didn't even make it to the garage, and are still in the box. Bought them to address roll centre correction but achieved the same by cutting the top off the whiteline bushes I already had installed so didn't use these. My loss, yo gain. Fits a number of vehicles; details here on the GK Tech website - https://au.gktech.com/polyurethane-rear-subframe-bushes
$110.
20190101_174621.thumb.jpg.8a3817f66949bf5ac2d80309a5a907f8.jpg20190101_174625.thumb.jpg.b842849d10a49d7cf9a7b980c7b6f5a3.jpg
Apexi SAFC NEO. In excellent working order and worked well for me, but now have a standalone ecu. In good working order as pics show. Has a strip of thermotape across the top (protect it from being roasted when parked in sun) - not an issue, but to mention it for detail of condition. Other than that, bloody choice bruv.
$200.
20190101_163100.thumb.jpg.e97bcc1c6e5d1405d4df75d164d17616.jpg20190101_163034.thumb.jpg.4a1cff2a01e93a3e24690182e0a77c57.jpg20190101_163051.thumb.jpg.eb85da45851d6041f2d8810c8b315077.jpg
Tein S-Tech springs, full set of front and rear- for R33 gtst plus others. Bought when I thought my coilovers has developed a knock but they hadn't, so these are test-fitted only - otherwise brand new still in box. These are the firmer type around 4.5kg from memory? so halfway between usual aftermarket springs and hard coilover springs. Possibly the best lowering spring for a street car that you can get.....possibly. Saw a post about counterfeits going around - check the logo and part number printing in the pics; they're genuine Tein.
$300
20190101_163355.thumb.jpg.baaadb6b31acfdc7838f891309d45049.jpg20190101_163415.thumb.jpg.1d02c20c57e9db8b37ad2c596548fa2f.jpg20190101_163323.thumb.jpg.726effd265a3e4d78361f8a8e32bd367.jpg
also have
- r33 gtst auto non abs tailshaft - R$30
- set of 6 r33 stock injectors - $20
- R33 gtst front LCA's, welded braces/boxed with Hardrace rubber bushes, VGC. $50
- R33 gtst stock front and rear camber arms, rear traction arms - $20 a set.
- GkTech hubcentric wheel spacers for R33/34, S14/14 etc - in 10mm, 13mm and 15mm thickness - $25 a set
also - ARP main stud set for RB25DET - BRAND NEW still in box...although as you will know, these come in a plain white box as not an 'official" ARP product in their usual logo'ed box (put together by their dealers? - genuine ARP though). Bought for the engine rebuild I never got around to rebuilding. Only thing is I used the lube sachet for my head studs, so no lube but otherwise complete.
Think they're around $350? steal then at $250.
no we're not done yet - B&M oil cooler - multipurpose, but I used it as a auto trans cooler. Thick solid construction, laughs off flying road pebbles with ease. Comes with ducting and custom hardlines and mounting brackets - is 100% bolt on to your existing factory mounting points and rubber lines, for R33 gtst, in drivers side front of wheel arch.
$100
Stainless steel intake pipe and silicone joiners for r33/r34 gtst. Has the fitting for BOV return (2 in fact, if you're running aftermarket instead) and PCV return line. Also thermotape-wrapped for your pleasure.
$50
Are you able to measure the length of the R33 LCA's? Need new ones for my s15 if they are the same (think they are)
Bushing to balljoint would be great, cheers.
ehhy for sure my friend for sure, i do for you. It measure 395mm from tip to tip shown 'ere.
B&m trans cooler and intake pipe now sold. Cheers to Rustynuts for a very smooth transaction.
Pm replied Josh.
price drop on Tein springs, $250, and further info
SPECIFICATIONS
- Front Spring Rate: 4.1 kgf/mm
- Rear Spring Rate: 4.4 kgf/mm
Ride Height Drop (ECR33)
- Front: 32mm
- Rear: 30mm
On 1/4/2019 at 7:45 AM, iruvyouskyrine said:
Sweet i will measure mine tonight and get back to you, cheers
FYI, R33 arms don’t have the hole w/cup for the S15 swaybar link. Bump stop is also slightly different.
  • 3 weeks later...
Nismo FPR now off vehicle, ready to go.
Also have - BrakeWest s/steel braided lines. These are ADR compliant/stamped, and a very high quality line - same layout as stock with the mounting blocks built into the lines. Think Nismo but a little more heavy duty construction. Used but in extremely good condition. Front only sorry, I still use the rear lines.
$40, or add $15 postage anywhere in Oz.
Another 3in stainless intake pipe. Has ports for BOV and PCV return, and is thermowrapped. This is the lower section only this time. You need to use a 2.3in>3in reducer from turbo to the pipe, and the reducer pictured is 3in>3.5 (I have now gone 3.5in all the way so this section not needed). So use either another bit of 3in routed to your afm/filter/whatever, or go 3.5 (gave me a little better throttle response).
$50, or add $18 posted anywhere in Oz.
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
