Hello there and happy new year :D
I figured I'll start this year by putting some more horsepower under the hood. I'm currently running a R33 GTST with minor mods like FMIC, oil cooler, steel head gasket and Power FC which produces about 320hp. My initial target (on the road to 7-800hp) is about 420hp to make sure I learn to control the power but also not break the bank.
I've already acquire new manifolds as I'm going for a top-mount turbo. There are some minor things that I'm not 100% sure about that I need your guys opinion on. I'm thinking of the following:
- DW340 fuel pump
- ID1050x injectors
- Billet fuel rail (https://www.billet.net.au/products-page/nissan-fuel-rail-kits/billet-performance-products-rb25det-fuel-rail-kit/)
- Turbosmart 800 FPR, is it a good fit or should I consider something else?
Thanks in advance :)
Edited by noperope
https://www.sau.com.au/forums/topic/475746-advice-on-upgrades/
In a forum first record you have actually picked good quality and correct modifications.
Only thing i would reccoment changing is the DW pump to a Walbro 460.
What turbo you running? Manifold? Gates? Clutch?
Also sell PFC and buy link G4+ plugin ECU, far superior.
The above information is very good, just keep in mind the wiring of the Walbro requires some love. Nothing crazy, plenty of people have done it without issues, but it's not as simple as "just connect to stock wiring" which lower pumps may be. I don't know if the DW340 is in that category either, but it is something to keep in mind.
Turbo choice is critical for a turbo car (duh). Clutch and Gates and setup may/may not be something to keep in mind depending on how future proof you want your goal to be, i.e 300-400hp on the way to 700.
It is exponentially better to go for the end goal from day one. It is also exponentially better/cheaper/more fun for your $ for that target to be the 400hp one instead of the 700hp one.
I am yet to hear of anyone ever regretting upgrading an ECU. Link G4+ or a Haltech Elite, if you can get something that is plug in you will be doing yourself a massive, massive, massive, massive favour.
Thanks guys! Yea I realize there is some information missing. When it comes to turbo I got a hold of a GTX3076 (gen 1 though), I know there has been some discussions regarding the spool being laggy but I'm taking a bit of a gamble on that part and it's something I can live with. It should support me up to 640hp but at that point there will be bigger mods.
I already acquired the fuel pump during the holiday discount, the DW should actually, from what I've read be an easy install, but hey, we'll see.
The clutch is a bit of a mystery, as I don't know the exact model I don't know how much it will hold up for, however, it's a equivalent stage 2 and if it gives, it gives.
The Link ECU is certainly something that I would like to get installed, there are plugin available but they're not cheap. I'm already stretching the bank a bit for this project, I suppose the PFC ain't going to sell for much anyway.
When it comes for going for the full power from the start, well, I know myself too well lets say, ain't going to be pretty :)
GTX3076 is a pretty solid choice for a turbo. It's not the worlds best, but it's far from bad in the grand scheme of things. It can certainly generate enough power to destroy your motor.
Skyline builds really fall into two categories, one being your ~250-350kw mark where
a) Clutches last longer, easy to drive
b) Rear grip is plausible
c) Lag is not too bad
d) Single fuel pumps work on E85 or Gasoline
e) Can arguably get away with stock manifolds, low mounting, stockish type looks
f) Stock engine internals last longer (not forever)
Going above that means points a to f and likely many I have forgotten need to be addressed
"addressing" these means you advance the weak point to whichever problem you addressed least. It is rarely more expensive at that point to aim at 500KW instead of 351KW and ends up being a "replace everything" type of thing.
There is no setup that will work at 550kw that will work at 250-300kw unless it is a 550kw setup that has been turned down massively which is going to be sub optimal anyway as the turbo choice needs to be suited to your intended power.
The smartest thing anyone can ever do is make an informed decision about what they want, and stay on target. Everything else is going to make you sad and broke.
From what I've read the GTX3076 is rated at 400-640hp which brings it just in range of my initial safe goal. With safe I mean a tune that won't push the boundary of what the engine can take at this point as it's my daily driver. The plan after this is done is to attend to the internals and replace everything but then again, stay safe tune wise to have an engine that have a high probability to not blow up :) The ECU is of course something else that needs upgrading.
I was told by my tuner that the engine could, with stock internals hold up for about 450hp (stock head gasket would be below 400hp) but there is an increased risk of breaking pistons/rods so having a tune of max 400-420hp would be a better choice. Any opinion on this?
I did 499hp on the stock HG and ARP studs with 25psi on E85.
Lasted a few years of track abuse, skid pans, more anti-lag launches than you'll see in a WRC season before it smashed a bunch of ringlands, valves, turbo, left metal lodged in the head, valves, turbo, exhaust. Followed by metal shavings in the oil cooler system, sump, pickup etc. Lol
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
