Hello,
I have recently purchased a 91 gts-t, I was told that it had a rb25 block and a rb20 head. The block has a cast number of 08U. If someone could help me identify this block and maybe tell me where to look for identifying numbers for the head I would be in your debt.
Thanks.
Edited by Vicariousness
https://www.sau.com.au/forums/topic/475751-trying-to-identify-my-block/
10 minutes ago, Rusty Nuts said:
R33 and R34 vct blocks are 75T .   I read somewhere, can't remember where, so don't lay money on it, that R32 RB25n/a blocks had 08U marking.
So it might be a rb25de? Well it has a big turbo and allot of other upgrades, I read that wasn't good for that engine.
2 minutes ago, Ben C34 said:
Does it run good? What fuel are you using? Do you not beleive previous owner for some reason?
It runs great, pulls hard and boost great. Hits 1.1 bar. I use 94 in it. I am just trying to verify the engine. Really wanna know for future mods and for knowledge of the car. As I have only the knowledge of what I have been told and that cast number is the only way I know of identifying it. And I haven't found a solid answer anywhere on what engine it is.
  • 10 months later...
  • 2 months later...
On 12/1/2019 at 8:10 AM, Gabgio Tez said:
Cylinder Head Identification for RB engines
what is your source on this information? do the RPO codes also translate to the blocks for those models. if not does the source provide a similar graph for the block identification
1 hour ago, Rusty Nuts said:
The source is this very forum. Iruvyouskyrine put up the information January
Good good, I shall keep digging and reshape the information back to this thread so as others who come across it wont need to do the digging ( that is if someone doesn't beat me to it )
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
