Hi,
Something strange has happened earlier today on my 32 GTS-t. I turned on the Aircon today and the car could not hold idle. It dipped below the 900rpm idle point for the duration that the Aircon was on (wasn't on for long, cos the engine was practically about to stall).
Ever since this happened, the car has had trouble idling.
The car has a chipped ECU (dr_drift), dry element POD, the AFM doesn't have a mesh, stock BOV + plumb-back, and the previous owner (only bought this car 3 months ago) said he has changed the O2 sensor prior to sale (have receipt for the O2 sensor). The exhaust (3" exhaust + running rich at idle) has been popping heaps more than usual as a result of this strange idling problem. ;)
Also, the fan belt has been really squeaky of late (changed from recent 100000km major service will all belts changed). Could this be affecting the idling?
Any help would be greatly appreciated.. :)
https://www.sau.com.au/forums/topic/47577-idle-problems-on-my-r32-gts-t/
when u turn the air con it uses more power therefore petrol so it might dip but then it sorts itself out and comes back to normal. well thats my understanding from having the same car and incident.
Yea I expected it to do that... but not to the point of stalling. Full-on the tacho needle dropped to the first little notch above 0rpm when I turned it on. :)
And once the aircon is on, I would've expected it to hold idle after the idle stepper kicks in. But it rises and dips from anywhere between 500rpm and 1000rpm. ;)
Hi,
Aside from the (dubious) performance gains, I was told by a friend that an earthing kit can help with idling? I was also told that it can also help with the electrics in the car...
This friend of mine has installed one in his 180SX and has found that all his electrics and engine idling have improved... Can anyone with an earthing kit installed provide some experiences on whether this is the case?
Thanks fellas.
I think I will give the earthing kit a try. I actually cleaned out the AFM 2 months ago followed by 100000km service. I'll try cleaning it again, but I hope the earthing kit does the trick... I've noticed that sometimes when I step on the brakes my stereo cuts out for a brief moment...
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
