Hey guys
I'm having trouble finding replacement bushes for the V36 coupe 2011 steering rack.
I just need one and i'm not keen to buy the whole steering rack just for one bushing
i've seen V35/350Z bushes come up on a google search but nothing for the V36/G37
I don't think it has a part number and nissan won't sell it.
If you can figure out the size of the bush and tube insert, try going to the Superpro website they have a section called Find my bush size, small possibility they have a bush thats close. I got lucky with a BMW bush I couldn't match. Had too reduce the length though.
Yeah I just found that site :)
got to get the ruler out and do some measuring
thanks
Well it's not easy to measure ?
I asked my Mechanic and he said he would charge hours of labour just do this.
Does anyone have there V36 or 370Z in pieces to measure the bush I need?
I'll do some more googling tonight too.
  • 6 months later...
Not good
Had the rack removed to get measurements.
It's all sealed up and you would damage the rack if you tried to remove them. Then you wouldn't be able to fit new ones.
My mechanic has just greased up and tighten them down. Now I don't have any movement problems so I'm happy.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
