Hi SAU, happy NY to you all.
I'm looking into a power upgrade for my 32gtr, educating myself on options. I've done a fair bit of reading on SAU and elsewhere, and now I'm hoping to get some advice about turbo selection from experienced folk here.
Currently running:
Mild 2.6L with forged pistons and rods, fresh mild ported head, oem cams, adj. cam gears, JUN oil pump, extended sump, oem cold side, N1 turbos. With supporting mods this is good for a modest 281kw at the wheels on 98.
Goal:
380-400kw at the wheels, with a nice wide torque band and response that is no worse than current, and preferably better. This is a regularly driven street car that will see the odd squirt here and there, cheeky track days etc.
Some considerations:
I think I'd rather go EWG and get the manifold + wg + bov stuff done, in preparation for an engine refresh inc stroker upgrade in future.
Some of the thoughts/suggestions so far:
EFR7670 ewg 1.05 - highly responsive but limited to around 350-360kw on 2.6Ls?
EFR8374 ewg 1.05 - good power but better suited to 2.8L?
GTX3576R GEN II 1.06
Thanks in advance!
Edited by shodan
Currently running:
Goal:
GTX3576R GEN II
Thanks in advance!
Go with the 8374. You will NOT be disappointed
Not likely a 7670 would be limited to 350 or 360.
My stock donk Evo 9 makes 325kw with 500nm by 4000rpm with 24psi. A well setup 7670 should blow around 420kw "all in" give or take.
Id say 8374 if you were prepared to go V cam. But i personally think itd be a bees dick too big for a nice street setup.
Though in saying that itd still be on around the same time if not sooner than a set of 9s or 7s ?
This part might explain the power targets: Mild 2.6L with forged pistons and rods.... on 98
If 98 is a restriction than that kind of power with "no worse than current" response is impossible.
That said, something 8374 sized is going to be a minimum requirement if 98 is a must have. With an 8k rev limit the 8374 is going to be my vote too. I had a 7670 on a 2.8 and it was nosing over up top at about 6800rpm.
This was OK for me as mine was a RB25 based 2.8, not a RB26 based motor.
This may or may not be perfect if you prefer revving to 7500 instead of 8500 depending on the kind of RB26 owner you are ?
To be on the safe side of everything I would be thinking something 8374 sized is likely the best compromise of running things with safe overheads.
Ahhh Fuark what a dope...  Missed that bit! ?
Well then if 98 definately 8374 1.05 ?
Yeah sorry, didn't really make it clear I'm not running E85- fuel system upgrade is another phase for the future.
My N1s would be similar to 7s I guess, so I could live with similar performance. From the EFR threads I read several positive comments re pre-spool transient response
Edited by shodan
Thanks for pointing that out Lithium. I averaged that figure from anecdotal comments, from the EFR threads here and elsewhere. Can I ask about your experience or knowledge of cars with either 7670s or 8374s on stock capacity RBs? , you seem to be fairly involved with car dev in NZ
I'm not at all surprised at your response
Yeah 98 for now. E85 sometime in the future.. Good advice thanks mate. I did read your EFR thread comments about the 7670
3 hours ago, burn4005 said:
8374 because eventually you'll want e85 and 480kw+
I had 400kw, got over it and now I have 500kw. I like 500 better.
Haha I'm sure that's exactly how it goes. I have been considering it for sure. Just wondering if I'm better off with the 7670 for a boost in response now, (and live with reduced total power) then moving to an 8374 when i eventually go 2.8.
  • Like 1
6 hours ago, shodan said:
Where do these fit in the Garrett pecking order? Better than GTX? different?
Brand new release for 2019 and improved over GTX range i believe.
Although have not seen any real world data just yet.
I'm telling you...the 8374 will CRUSH your N1s on boost threshold, response, overall power, midrange torque etc...yes on even a stock 2.6
I have a car with new -7, fresh motor, camgears, haltech. Then I just installed a .92 8374 efr on a stock 2.6 car. No kidding the efr absolutely destroyed them both as a better operating engine. I think it's pointless to go with anything smaller to be honest because you really don't spool any faster...only reduce topend.
  • Like 1
On 1/9/2019 at 7:47 AM, Kinkstaah said:
This may or may not be perfect if you prefer revving to 7500 instead of 85009500 depending on the kind of RB26 owner you are ?
Fixed that for you
Mate of mine is doing a 26 7670 build should be running in the next few months, will be interesting seeing how it goes compared to my 8374. Can't say i'm 100% convinced its the better option for pure street duties, though wouldn't go a 7670 for the track etc.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
