Hey guys I’m stressing out now not sure if i made the wrong decision.
I just brought my first ever r32 gtr v spec.
Went to have a look at the car was clean inside and out rust free this that I really wanted that car.
Compression test 120psi over all 6 cylinder
my mechanics friend said get it engine old it’s got wear and tear and shouldn’t be a problem engine could last u another 5 to 10 years who knows.
Snyways so I brought the car and now I’m gonna put some power in the engine now not crazy just 300kw-350kw 400 tops
 now I’m really worried and stressing if my motor is gonna hold or did I f**k up with the purchase and now have to spend a ton of money on rebuilding the bottom end ?
https://www.sau.com.au/forums/topic/475812-compression-test-120psi/
If it's showing signs of wear and tear I wouldn't be throwing 300-400kws at it...
If it's running without a hitch, I would personally buy a new block and start from scratch to reach those power figures while cruising the streets in your stock motor.
Welcome to owning a GTR. You'll forever be stressing about something haha.
  • Like 2
Yeah I got apexi power fc but last owner whip all data and hand controller not connected
 I’ll prob just get controller hooked up check on tomei exhaust and get a tune and cruise around
n do what u said get another block on the side and start from scratch
Whats the history of it? Id be looking under the covers to check if the cams are aftermarket.
A set of fat cams could drop it 30psi, plus retarding the stock cams would lower it and if someone put some silly low comp pistons in.
Do a leak down test, check the plugs, see how much blow by its making etc..
