Hey all,
Decided i would knock this up to help people ID what cylinder head they have. The list is mostly complete and i should have it finalized in the next day or two.
If people could cross check with what they have on their vehicles that would be awesome.
The casting ID is located somewhere around cylinder 1 and is ia 3 number/digit code. Attatched is a pic of an RB20DET so you can see the casting number.
Cheers
  • Thanks 1
If you want to confirm the casting numbers they are the 6th, 7th, and 8th numbers in the Part No.
ie R33 RB25det  part. no. 1104075T00
    R33 RB25de    part no.  1104075T00
     R34 RB20det  part no.  11040AA000
Edited by Rusty Nuts
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
